Question about Panasonic CT-32SX12 32" TV
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time
  • 5 more comments
  • sav1997 Sep 11, 2007
    where do I check the power supply? from the outlet or inside the tv? sorry for needing the clarification
    sorry also whats "hunting"
  • sav1997 Sep 12, 2007
    how do i know if it is good or bad. sorry for being a novice. I am assuming that I need to take the back off and look for the part?
  • sav1997 Oct 29, 2007
    well that sucks I was hoping to save it...it still has a great pic other than shutting off...and on
    no solutions for it than I suspect...go figure with electronics
  • rtalassaf May 08, 2008
    my tv turned off after 3 to 4 sec and the lid lights still green every time i turned on its turned of again today its the fourth day i try ed to unplug but it dose nt work thanks.
  • Anonymous Jul 06, 2008
    same problem is there an easy fix or should we toss it
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Posted on Sep 11, 2007
  • manahar modern Sep 12, 2007
    no of times on off on off is called hunting
    power supply is the place in tv where you give ac input& you get dc regulated output
    regards
Lg tv power light comes on but screen stays blank
If you can't see a faint picture with the flashlight then the T-con board is gone. If you can see a faint picture, then the led driver or ballasts for the back lights quit. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | LG Televison & Video
Screen goes blank, but sound is on
Most likely a bad power supply. If this is new I would send in for warranty. If outside of warranty then pull this apart and find out the board model and number. You can find most online.
Apr 09, 2014 | RCA Lg 42ls5700 42" 1080p Flat Panel...
My 19v712m manga box tv goes black
The steady blue LED merely indicates that power is getting to your TV. The internal power supply may have failed
May 15, 2013 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic CT-32SX12 32" TV Logo
461 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
