Question about Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher
Maytag MDB8600- After setting to Heavy load,
Maytag MDB8600- After setting to Heavy load, closing door, and pushing start, dishwasher returns to rinse cycle.
  • 3 Answers
SOURCE: Maytag MDB9100AWW Dishwasher
We have this same model. Right under the 5 yr warranty mark, the control panel started going "funny". Some of the buttons stopped working, then more. We could finally get it working only in one mode. I was certain it was the control board, which I replaced under warranty just in time.
This lasted another year, until moisture began appearing under the number window and the left side button set stopped working. Now the right side is gone, except for the delay-start button.
I believe moisture is getting into the control board and frying it, either slowly or quickly. If you are seeing similar problems where buttons seem to stop working, it is PROBABLY the control board. It is a relatively easy home repair if you know your way around a screw driver.
Posted on Dec 31, 2007
SOURCE: maytag dishwasher MDB5600awb
Please help, I have a MDB5601AWW, It will not start. It only makes a litter sound click and lights the green light on. That is.
Thank you for help
Posted on May 09, 2008
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
Trouble-shooting non-starting
When you perform the key dance of normal heat dry normal heat dry, that is DIAGNOSTIC MODE. The heavy black material is called "mastic" and has come loose from inside the door panel--the door panel must be replaced. I've seen the mastic come loose from heat and fall out of the bottom of the door. It acts like an insulator for sound and heat. It helps keep wires in position, etc. The dishwasher stopping could be from a clogged filter in the main pump, or a clogged drain motor. If the drain action is too slow, the computer will time out and stop. If the main pump is strangled for enough water due to a blocked filter, it will shut down to protect itself.
Aug 17, 2015 | Maytag Dishwashers
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
Maytag mdb8600
Request a wiring diagram directly from Maytag.
Oct 24, 2017 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag quiet series 200 dishwasher won't start
I had a similar problem. Turn off the power to the dishwasher. Open the door and remove the screws on the back that holds the door together. Now, locate the black control module and remove the cover. Look down at the bottom left of the control module and you should see a ribbon cable. This is the cable that connects the door keypad to the control module. Unplug the ribbon cable and the plug it back in. On my unit the ribbon cable was not making good contact and only half of the keypad was operational,
Hope This Helps !!
James D.
Jul 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Maytag quiet series
My manual says: 1- Close door. 2- Select cycle. 3- Press delay. 4- Push Start/Cancel. (As soon as start/cancel is pressed, the flashing should stop and the delay time will begin).
Mar 12, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher Logo
99 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
