Question about Pioneer VSX-108
Station Memory Loss Pioneer VSX-108
I have a VSX-108 and bought it used. It works great except when you turn it off manualy. I do not have the remote. When you power up hours later it does not retain the stations that I set up in memory. I tested the preset station prior to turning off to ensure that it took. I then powered it off and back and and still retained the preset station until I turned it off and then came back several hours only to find I had to reprogram the stations again into memory. What maintains the memory and can this be replaced by me a non tech. Receiver is not under any warranty. What is the part and cost. I googled this and it seems to be a problem of the VSX-108.
  • 1 more comment
  • Anonymous Nov 26, 2007
    yes i have the same problem. i do have the remote for it but the power buttons and the button directly under it do not work. where can i replace the remote and how much?
    [email protected]
  • teachers645 Dec 27, 2008
    I have the remote, and it does not put the receiver into stand-by.
    I do not believe it ever did. Is there a battery on the main board that needs to be replaced?
  • Anonymous May 23, 2009
    The above solution is incorrect. The remote standby mode is only for "other equipments". The vsx-108 does not have a standby mode. The operating instructions manual seys that the unit should remember settings when the power is off for several weeks. The unit must have a source of "keep alive" power for the memory circuits. This will be either a capacitor (most likely) or a battery. As I have not found a battery in "easter egging" the units guts I am assuming it"s a capacitor. I need a circuit diagram and component layout to find which cap to test.
    New Friend:
The problem is IC 701. I looked it up as far as pricing and it costs around 78 dollars. I am not planning on replacing it as it is not worth it.
Posted on Feb 04, 2010
  • 752 Answers
If you turn it off MANUALLY the power is physically cut from the mainboard where the memory is stored and it is lost. If you use the remote it puts the unit into a standby mode which retains the memory.
Posted on Sep 13, 2007
  • Dick Berry Sep 01, 2017
    Not true, the Standby button on the remote is for "Other equipment" see the manual.
SOURCE:
Pioneer VSX 454 loses station battery needs replacement where is it located???
Memory is not held by a battery. It is usually held by a capacitor that provides the micro with voltage. Not that easy to change.
Jan 04, 2013 | Pioneer VSX-454 Receiver
I have and older unit a pioneer VSX 3800, how do you program the radio channels, is there a manuel for these unit i can get sent to myself
Hi.
You have a digital display pioneer receiver and you would like to know how to store radio stations.
  • first tune your radio to your selected radio station
  • next see if the receiver has a button marked memory, and it should have buttons marked 1 2 3 4 5 6 etc
  • After you have tuned in to your selected radio station, if it has a button marked memory,
  • Press the memory button, then press and hold 1 for a few seconds and that should store your selected radio station to preset 1
  • Next, tune in to another radio station and store it by pressing memory then 2 and that should store it in location 2.
  • If your Receiver doesn't have a button labelled memory, and simply has the store 1-6 etc buttons then ,
  • Tune in to your radio station , then press and hold 1 for a few seconds, it will probably flash a few times until its stored in that location 1
  • Next, tune in to another radio station, then press and hold 2 and that should store it in location 2.
  • repeat.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Pioneer Audio Players & Recorders
How do i play my ipod through my pioneer VSX-108 receiver
I am using a sony bluetooth transciever md# HWS-BTA2W with a Y adapter into the Receiver CD audio in. Works great and I am able to roam about the house with my ipod playing audio through the VSX-108
Dec 22, 2010 | Pioneer VSX-108
Pioneer VSX-516-S/K amplifier - loss of sound in speakers
This sounds like the amp has a system memory problem. The chips inside your amp that deal with it might be faulty or they loose the information due to a power loss, often caused by memory retention capacitors.
You can tell that to the repair man and see what he says, but personal I would go to another, try contacting Pioneer for a recommended engineer in your area.
Apr 09, 2009 | Pioneer VSX-516-K/S Amplifier
Pioneer VSX-108 receiver
Sep 02, 2007 | Pioneer VSX-108
Vsx-108 preset resetting
I too have the issue. Any luck in your resolve? I am checking with a service center but would love to resolve it myself.
Dec 06, 2006 | Pioneer VSX-108
Pioneer VSX-108 Logo
1,155 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
