Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
How to turn up volume on siren. 791XV - 791XV The 791XV is a 2-way Security and Remote Start system. Th
I dont think you can turn it up. But I added 2 more sirens. The original is very small and quiet.
Posted on Jun 15, 2009
    Sniper:
  • 50 Answers
There are 2 loops on the siren. One will put the siren in a one tone mode and the other will make the siren chirp louder on arm and disarm not when the alarm is going off. If you do decide to add sirens, I would suggest using a relay.
Posted on Jul 05, 2009
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
Mar 12, 2012 | Cars & Trucks
What other remote can i use for the 791xv
The original remote is the 479V; you can also use the 472V.
Oct 16, 2010 | 791XV The 791XV is a 2-way Security and...
The car itself does not beep when the alarm is armed or disarmed
An output wire is not connected, you'll need to connect the brown wire on the 12 pin harness to the siren, it will be pin number 10. Either that or your siren is bad.
Oct 08, 2009 | 791XV The 791XV is a 2-way Security and...
Led light stays on
if you are finished with the install, then it's in valet mode. if you are still working on the alarm it's on because the alarm needs a ground.
May 20, 2009 | 791XV The 791XV is a 2-way Security and...
Got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Jan 31, 2009 | 791XV The 791XV is a 2-way Security and...
Viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
No install instructions
email me at face2face11@bellsouth.net and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Dec 31, 2008 | 791XV The 791XV is a 2-way Security and...
I don't know what is wrong... With my Siren Edge
Try windows Recovery Mode first:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jan 06, 2008 | Siren Edge MP3 Player
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
446 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
