Question about Delphi Roady XT XM Radio Receiver
Delphi roady xt
Turn the power on and all it says is xm satellite radio. Cannot turn it off after that.Exactly the same problem. It worked for about 2months. I turned it on one day and all I get is frozen display that say xm satellite radio. All buttons are dead and and I cannot turn it off. I replaced it with a new unit free of charge - but another 2 months later... SAME THING!!
    Brigadier General:
  • 8,619 Answers
Hi
As you already know this is the common problem with this unit however you can first try to reset the unit . Also check this Delphi Roady XT User Manual for more details. If it still does not work then the best option would be to get it replaced as its probably under warranty so to avoid any further problems. Also you can contact Delphi Consumer Electronics Technical Assistance Center at 1.877.463.3574. Assistance Center hours are: Monday-Friday 8:30 a.m.- 6:00 p.m. EST
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 12, 2009
My radio just recently goes up to 119 and several of the channels i listen too come up as updating....and won't play.
Give XM a call, since they merged the channel lineup has changed. Have them push a new activation signal to the unit, which should unlock the rest of the channels. However, the roady XT isn't exactly known for its reliability, so the receiver itself might be dead.
Sep 12, 2011 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Roady xt
I have the same problem... I found using a new cradle solved the problem.
Mar 18, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
94 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
