Question about Sharp 27K-S100 TV
I am trying to fix a Sharp 27k-s100 television.
When I press the channel up or down button it switches to Input 1, when I press the button again it switches to Input 2, when I press it again it switches to 3, when I press it again it swithees to 13 and it plays good, when I press it again it switches back to In put 1, can someone please help me?
  • tony Mungo Sep 19, 2007
    Thank you for your help it is working out good thanks yours anthony
  • tony Mungo Oct 26, 2007
    Almost there  still not  working good yet the color is off , trying to fix it , I  am going to buy a new indoor  antenna, and then I will  try to  adhut the color, may be this will work  do you think so? I thank you yours anthony
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Posted on Sep 11, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Please clarify more YHANKS
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
Video inputs not working
Looks like your son got into the service menu,(it`s rare since you need a specific combination of keys to get into it) and somehow managed to disable one of the input.I can`t tell you how to get back into it since it could do you more harm than good but any local tv repairman should be able fix that in five minutes.
Oct 30, 2009 | Sharp 27K-S100 TV
I turn the tv on and after a few seconds it shuts itself back off again. At that point I can't turn it back on until I unplug it and plug it back in. However, when I turn it back on it will again turn...
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
Oct 18, 2009 | Sharp 27K-S100 TV
How to switch to antenna usage without a remote for a sharp model 27K S100
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
Mar 22, 2009 | Sharp 27K-S100 TV
Picture is okay but sound is not coming
sound is not coming but picture is ok in philips 21 RF vardan tv
Mar 17, 2009 | Sharp 27K-S100 TV
TV will not stay on
You have done everything that a consumer can do. The problem is most likly in the horizontal section of the tv. This will be something for a repair shop to fix.
Nov 10, 2008 | Sharp 27K-S100 TV
Buttons missing on front
The part number is JBTN-1096MEKA this is for the power/volume buttons. Part number JBTN-1097MEKA is for channel up and down buttons. Order at Andrew's Electronics 800-274-4666
Jul 24, 2008 | Sharp 27K-S100 TV
Forgot v-chip code
Sharp has several locking and V-chip commands but one of these three possibilities should work.
Newer Combos With "Time Limiter" Feature
If the "Secret Number" is forgotten, simultaneously press the STOP, RESET, and VOL up buttons on the front panel of the set.
This disables both the "Channel Lock" and the "Time Limiter" features.
CTV's Lock Mode---Blue screen and display says,Parental Control Rating Unknown
Try This: Hold Channel up and down on the set while pluging in AC cord.
Or Try This: On the set, press volume up and channel down at the same time.
CTV's V-Chip Release
When screen asks you to "input secret number" press and hold channel up and down on the TV set until message disappears. Press menu 2 times to exit.
Hope this helps!
Bill
Nov 13, 2007 | Sharp 25R-S100 25" TV
No picture but there was a sound
1.service mode before putting unit into the service mode, check that customer adjustments are in the normal mode. use the reset function in the video adjust menu to ensure customer controls are in thier proper(reset)position. 2.service number selection once in the service mode, press the channel up or channel down button on the remote transmitter or at the set . the service adjustment number will vary in increments of one,from "S01"~"S19" to "M05". select the item you wish to adjust. 3.data number selection press the volume up or down button to adjust the data number. to enter the service mode. while pressing the vol-up and ch-up buttons at once, plug the ac cord into the wall socket and switch on the main power. now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Sep 19, 2007 | Sharp 27J-S100 TV
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Sharp 27K-S100 TV Logo
472 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
