Question about EPoX EP-4B2A Motherboard
Intel 845 motherboard (4b2a) beep
The beep is "ta na ta na ta na ta na"
Like an ambulance...
whats the prob?
Tnx!
  • ganda_maluco Apr 13, 2009
    Because it was not helpful...the motherboard is detecting all the RAM slots...if there was any prob, it should state less RAM than it shows...
    I had a 64Mb graph card and the prob appeared ( I have this PC since 2002) I changed to an graph card of 128Mb and after a few months the problem returned...the beep happens only about 2 or 3 times a month and I use it everyday.
First check that the motherboard HDD led is correctly fixed otherwise change the HDD ide cable.
Posted on Apr 27, 2009
    President:
  • 987 Answers
Try to change the RAM...
Posted on Apr 12, 2009
  • Sibananda Apr 13, 2009
    Why did gave me inappropriate rating ??
    Have u connected any video card ..if yes then it must be defective or the onbord graphics chip have some problem....
I'd not find the lan driver for intel 845 gvsr motherboard
since you you did not put what OS are u using,
try to find in this link :
http://www.opendrivers.com/categorycompany/1113/172/network-intel-free-driver-download.html
GOODLUCK
Mar 16, 2009 | Intel Motherboard
Bios gets reset whenever i turn on my pc
The battery on the mother board need to be replaced.
Dec 29, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Display problem
give me details your machine power up properly, its giving beeps continously, if not check your connection of motherboard or remove your ram and check it, its giving a beep
Oct 15, 2008 | Intel Motherboard
Intel 845 mother support
research the ram to see if it will work on that motherboard. some ram requirements are present when you get memory for a pc. not all ram are compatible with certain motherboards.
Oct 02, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
EPoX EP-4B2A Motherboard Logo
379 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
