Question about GE Kitchen Ranges
GE Kitchenaid gas range: When I unplug the range to clean; then plug it back in, how do I reset, so it operates normally.
  • GE Master
  • 3,361 Answers
Simply re-set the time of day on the clock.
Posted on Apr 12, 2009
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
What does "F9" on keypad signify on a GE JGBP35
Problem with door circuit. You may have a pinched wire between control board and door lock switch. Unplug range. Gain access to the control panel and unplug all connectors. let it sit for a minute. plug all connectors back in. examine wires going to the door lock, ensure that they are not pinched. check operation of the door lock. If problem persist, you may have to replace door lock.
Feb 08, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Control panel black -No display
no reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Jul 20, 2009 | KitchenAid KGST307 Gas Kitchen Range
Electric fault in computer on controls. System
You might try pulling the AC plug and leaving it unplugged for an hour or two to see if this will reset the computer.
Feb 23, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
I have a GE Profile Gas/Electric Oven Range that has stop working
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Nov 21, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
