Question about Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000
PS-1000 Seal My hot tub has a leak and I'm ready to install the replacement part, PS-1000. Do you have any instructions on how to replace the seal kit? I have the part but it didn't come with instructions.
  • Anonymous May 03, 2009
    How do you seperate the pump from the motor?
  • Anonymous May 17, 2009
    Can you define "knock it out" and what you mean by "properly sized driver"? We've tried to use pliers to pull it out, and a screw driver to leverage it out and it won't budge. It appears "frozen" and perhaps fastened by some unseen method. More explanation is needed please.
    New Friend:
  • 77 Answers
The seal replacement on most pumps requires the capacity to separate the motor from the pump and to dismantle the wet end. Upon dismantling, it will become clear as to where the seal components are to be replaced. The spring half is found in the seal plate and must be knocked out and reinstalled with a properly sized driver and the ceramic seat is attached to impeller. Be careful not to damage the polished surfaces of seal. A light coating of a silicone or teflon based lubricant is most helpful ..
Posted on Apr 14, 2009
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
I need to replace my out put seal on my hot tub pump. i need help getting the impropell off the motor shaft?
Take the pump to a motor shop. there is often shaft damage...and then bearing and bushing damage...
Oct 19, 2010 | Waterway Pump Part Seal Set Ps1000 Cd 319...
I replaced the seals and the wet end leaks right into the motor without even any pressure. I put all the parts back in...did I miss something?
First make sure that you have the correct seal. Then when you install it make sure that th graphite and the ceramic face each other. If it is a 1000 seal when you set the graphite side use a 1" PVC coupling to press it in place. If you don't have even pressure you will crack the graphite. Good luck.
Sep 28, 2010 | Waterway Pump Part Seal Set Ps1000 Cd 319...
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
I have a frigidaire affiniy front load washer. After I washed a lightweight blanket i heard a laoud noise from the machine and water was below the drum not behind from the hose. The next time I used it...
check these:
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further detail
Sep 18, 2009 | Washing Machines
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000 Logo
922 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
