Question about Maytag Dryers
I have a Maytag dryer, model # MDG9706AWW. It isn't producing any heat to dry clothes. Where do I start to trouble shoot problem
  • 11 Answers
SOURCE: Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
Posted on May 20, 2007
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 2692 Answers
SOURCE: Dryer not drying
Locate the heater element ,disconnect one or both ends. ohm it out with an ohm meter. Zero reading means tha it is open and needs to be replaced. Maxium or full; scale reading on the right side means that it is shorted and needs to be replaced. Middle reading on the meter and I would look elsewhere,such as;  Voltage coming to the element if you are used to dealing with 220 volts, live.
Posted on Nov 24, 2008
SOURCE: maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Posted on Jan 27, 2009
jonniewalker
  • 1029 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Maytag Dryers
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Check your heating element your lint trap and your exhaust hose.
You can check the element by opening the door pushing in on the switch and turn it on,you will feel or see the heat.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 18, 2009 | Maytag Performa PAV2200
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
