Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a Philips 9P5544C102
The Problem is, I am getting Double picture. I have tried to go into programming and line up the red, and white cross, but it will not let me do so. Please let me know Thanks Tom
  • Anonymous Apr 25, 2009
    where are the yoke resisters
    i changed the convergence resisters on the heat sink but need to know where the resisters are
  • Anonymous Apr 29, 2009
    were do i locate the convergence chip
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Tom You are experiencing a convergence output failure. The crosses will not move until the conv.. chips are replaced with original parts. There are also some yoke return resistors that have opened due to the chips flaking out. John
Posted on Sep 11, 2007
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Mark
Dec 30, 2010 | Panasonic Televison & Video
Seeing a picture like double vision.Tried to adjust the red & green crosses and the blue. The crosses or plus ( ) signs are supposed to be ontop of each other I assume?. What seems to be the problem.
They have to be on top of each other, converging perfectly. If you are unable to align them - you have convergence issue. Two convergence IC's have to be replaced inside of your TV. I would strongly recommend to let it do by professional technician.
regards.
Russ.
Aug 12, 2010 | Philips Televison & Video
55p9363h/17 The picture has bright spots throughout it and it's not very clear. I cleaned the bulbs and the mirror inside. The screen was replaced also. I went through the contrast settings too. None of...
Do a static convergence on your set. You should be able to go into the main menu and scroll down to picture and press select. Then go to convergence and press select. A white cross will appear use on screen direction to line up all the colour crosses behind thie white cross untill they all appear white. Then press continue and you will see several white crosses do the same for each one of these crosses. this should solve your problem. If not u have some bad convergence chips
Aug 08, 2010 | Philips 55PW9363 55" Rear Projection...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Alot of red and double image
I had same problem. First went in tomenu and went to set up settings and went to convergence area. I then reset this back to default, which I later was told I should have not done so do not attempt this it will temporarily fix issue but problem will persisit.
I found a local tv repair man thru tvrepairguy.com or something like that as they are hard to find.
The issue turned out to be the convergence boards or circuits, He then went in to master control and rset the convergence settings for the main picture by lining up the red and blue lines on to a white cross on the screen until it is black and white with no red or blue protruding vertically or laterally. He then did this for 7 points around center picture moving the lines. He suggests you play with this for awhile in a position you would normally sit in and at proper eye level to give you the truest picture for alignment. The part cost 109 to replace with labor and service total was 331. The repairman was very nice and explained the issue should be fixed and we should get another 6 to 7 years out of television.
Hope this helps,
Dec 04, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Double picture
convergence issue - has the set sustained a knock?
either way, it will require expert help or at very least access to a cross hatch generator
Nov 22, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
