Question about Home
Water not hot enough coming from my power shower
I have a redring superflow 3000 power shower and the water no longer gets hot enough even on max setting. Any ideas on what I can do other than replace it for a new one?
  • mandygrayson Apr 17, 2009
    Am replacing it as unable to get parts required. Thanks for your help anyway ;-)
  • joebren May 11, 2010
    i have a power shower but the waters only coming out warm not hot
  • 88 Answers
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
  • Bati99
    Bati99 Apr 18, 2009
    I hope the new one works better!
Does any one have an old redring superflow 3000?I need the control lever (on the front that turns on the pump). I'm willing to pay for it :)
Thanks
Nick
0044 7956 533633
Posted on Jun 21, 2010
Selectronic redring shower powering up , no water coming out and then turns off after approx 10 seconds
There are some troubleshooting actions mentioned on page 6 and 7 of the manual at this site
http://www.aroundtownflats.com/manuals/Shower%20Manuals/Redring/New%20Selectronic%20Instructions.pdf
The shower is designed to turn off within 30 secs if there is no water flowing through. The issue is why does water flow stop.
It can happen if shower is in overheat shutdown. Need to find if temperature setting is too high. There is a purge sequence to overcome this. See manual.
Apr 21, 2014 | Home
Only cold water coming out of Redring digitemp shower
The temperature sensor in the unit is not functioning. It needs to be replaced!
Jan 14, 2013 | Home
My Grohe Aquatower 3000 shower is wonderful BUT after 5 or 6 minutes, the water starts cooling off. Is there some adjustment to keep the water warmer for 10-15 minutes?
You are lucky that your shower is lasting as long as it does. If you have a standard 40 or 50 gallon water heater, mixed with 30% cold water as it comes out, you can expect about 60 gallons of hot water, give or take a little bit. Each of those showerheads on that Aquatower is rated at 2.5 gpm. Even if you are just using the body sprays, you could be using 10 gallons of water EACH MINUTE. There is really only two things you can do, and that is to raise the temperature of your hot water heater by 5-10 degrees so you are mixing more cold water with the hot. The other thing is to buy a bigger hot water heater, or supplement the one you have with another water heater in series.
May 03, 2011 | Home
When our water heater is used alot like to shower and wash clothes all in one evening it shuts off. no hot water for shower in the morning.we replaced the element already and the thermacouple
make sure check both elements with a voltmeter, when one element quits working you don't get enough hot water, check for power to both elements too..
Oct 05, 2010 | Water Heaters
I have redring expression 500, the power is on but no water coming through, no noise from the shower. could this be the solenoid valve
Replace the shower unit.There never worth repairing after five years use.You could end up paying £80 for a plumber and £60 for a part and something else goes in 6 months
Aug 06, 2010 | Home
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
PRICE PFISTER TREVISO SINGLE HANDLE SHOWER - WATER NOT HOT ENOUGH
Check the manual that came with the unit and it should tell you how to adjust the max temp inside the fixture. Hope this helps!
Apr 02, 2009 | Price Pfister 048-DZ00 Oil Rubbed Bronze...
Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil
www.redring.co.uk
http://www.protimbathrooms.ie/downloads/pdf/RedringBrochure.pdf Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
http://www.applied-energy.com/clientfiles/File/manuals/redring/Powerstream%20Instructions.pdf
Dec 28, 2008 | Home
Home Logo
1,383 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
