Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Problem for Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Unable to use play/edit mode of DCR-HC30
By greghatrick on Apr 12, 2009
Whenever I try to set my camera to play/edit mode, it will briefly display the screen and then immediately skip over to camera-tape mode. Sometimes it will actually stay in play/edit mode for several seconds, but eventually it switches over on its own or if I try to use any of the buttons.
I looked through the Guide and did not see any troubleshooting for this problem.
My camera is not connected to the computer. The battery is charged, and this problem is very recent.
This problem happens with all usb settings (I was trying to transfer video to my computer).
Thanks for any help.
Comments:
Apr 12, 2009
- Oh no, its just that first problem. The play/edit mode is not working.
I was just adding extra information.
Clarification Request
Posted by welcomejee on Apr 12, 2009
Are you asking 2 problems with same camcorder DCR-HC30..
1= Whenever I try to set my camera to play/edit mode, it will briefly display the screen and then immediately skip over to camera-tape mode. Sometimes it will actually stay in play/edit mode for several seconds, but eventually it switches over on its own or if I try to use any of the buttons.
2=My camera is not connected to the computer. The battery is charged, and this problem is very recent.
Let me know what exactly you are looking for?
Same Problem
May 20, 2009
-   Same problem with DCR-HC48E. When i rotate wheel rotor to right to change from tape mode to memory or play/edit the camera beeps the sound and the green light remains lit near the tape mode position and do not change to memory or play/edit mode. So it is imposible to set the camera to memory and play/edit modes. Sometimes after hundred times of rotation of rotor the camera goes to memory or play/edit mode, and than it can play tape ok. The problem is that it requires a hundred of tries to go to play/edit mode. Any solutions, or suggestions what to check?-   Guest
Solution #1
posted on May 28, 2009
Not Rated)
chakemco
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem. I was attempting to transfer video from the HC30 to my Windows PC via the USB cable. Unfortunately, the software supplied with the device is not compatible with Vista. Since then, whenever I switch the mode to PlayEdit the screen displayed "USB MODE disconnect the USB cable before...".
I called Sony and they had me try several reset options without success. Then they said they I could send it in for a flat fee of $171.00 plus shipping to troubleshoot; parts would be extra. The camera is only worth 150 bucks.
My solution:
All devices that retain information such as date and time have a back-up battery, so I wen online and purchased a DCR- HC30 repair manual for 8 bucks. I found that the MS-200 board under the tape loading door hs just such a battery (although it is soldered in place and cannot be removed).
Following the dissambley instructions, I dismaltled the camcorder and disconnected the flexible board that links the MS-200 board to the main processing board, then reconnected it after 5 minutes.
I then reassembled the device and to my surprise, it functions normally now without displaying the USB error.
Here is a link to Tradebit, the site that sold me the repair manual:
http://www.tradebit.com/filedetail.php/7066542-sony-dcr-hc30hc30e-video-camera-recorder-service-manual
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam DCR-HC30 Mini DV
Questions and Unsolved Problems for Sony Handycam DCR-HC30 Mini DV
Do you recommend Sony Handycam DCR-HC30 Mini DV Digital Camcorder?
Answer
Answer
How do I transfer video (tape) from my Sony Handycam DCA-HC30 camcorder to my MacBook?>
Answer
When you try to record, it gives a beep beep beep about 4 times and a small orange light appears. I... (More)
Answer
on both the lcd screen and the viewfinder the image is all screwed up with lines up and down the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorders Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
