Question about Maytag Neptune MDG5500AW Gas Dryer
Longer time to dry clothes
My Maytag neptune dryer takes a longer time to dry clothes lately. I suspect that there is a lot of lint in way of exhaust air and prevent the sensor/thermostat to function properly. I would like to check but I don't know how to open the front panel of the machine.
I really need help on this one.
  • alshu May 03, 2009
    Longer time to dry clothes" on Maytag gas dryer;
    Any thoughts
  • Maytag Master
  • 3,361 Answers
Remove the rear connecting vent and run a 45 minute timed dry load. If it works correctly repair the connecting vent and or blockage in the wall.
If this does not correct the problem make sure the glow bar is cycling at the gas valve and report back for further repair.
Posted on Apr 12, 2009
Dryer drying slower
Check lint filter. Check blockages in the exhaust hose. Check that the flap outside your wall is not blocked and that the slats or flap opens OK. To get fast drying you have to have a good airflow into the drum and out of it.
Oct 22, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
Clothes are now taking much longer to dry. I have cleaned the dryer vent & vent hose. ( all the way to the roof as I did once before that rectified the problem then.) Wet lint is around the door and...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer takes a long time to dry
there is no truth to the fact that dryer elements start to burn out there fore it takes longer to dry cloths the only reason a dryer will take longer to dry cloths is due to lint build up within the unit take the back off and vacume all the old lint out and around the heating element and it will work like new
merry christmas
Dec 21, 2010 | Maytag Dryers
The lint is not getting caught in the lint trap, the vent tube is full of lint, and the clothes are taking longer to dry. Is there a possible blokage inside the dryer?
Yes, maytag has two screws located on front bottom. Take off front of dryer and vacuum out everywhere in the machine and the exhaust line. Check your belt as this is a good time to change it, if you have never done so, you may need to take a digital picture to aid in putting on new one; its a little tricky. Good luck!
Nov 06, 2010 | Maytag Dryers
I have a Magtag Neptune dryer that recently began taking a long time to dry the clothes. I noticed that the exhaust hose was not very secure at the dryer and there was a lot of excess lint could that cause...
a vent hose that is full of lint or clogged/restricted will cause the dry to take longer to dry or leave the clothes damp. if you clean/get the hose unrestricted this should rectify the problem. Hope this helped tim
Sep 01, 2010 | Maytag Dryers
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Too long to dry my clothes
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
May 03, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
329 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
