Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
Air conditioner constantly shuts off
One day I smelled smoke coming from the AC outlet. I have a extention cord coming from the unit into the AC outlet because it isn't long enough. I immediately move the plug to another outlet. Now the AC runs for about 10 minutes than breaks the circuit breaker. Can anyone help me resolve this issue?
    Novelist:
  • 87 Answers
Are you saying that you have plugged the aircon into an extension lead then into a socket in the wall and that the smoke was coming from the extension lead part. If so I would suggest checking all your plug in connections and chenge the extension lead. A quick way to check the compressor is a cause is to put the aircon to fan only and see if it fails to trip out the circuit breaker, then put it back onto cooling and see if it trips (if it does on cooling then its a good possibility). Most aircons have a three to five minute time delay for starting the compressor to protect against power fluctuations (ie power cuts). Hope this s of some help.
Posted on Sep 11, 2007
Air conditioner smoke
I could be that the evaporator core started to freeze up and what you saw was the steam coming off of that.
Jul 18, 2013 | 2004 Nissan 350Z
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Jun 02, 2010 | Maytag Heating & Cooling
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
I have three window ACs in my entire mobile home(double wide). One at the back of the house, one in the middle and one in the front. Each one is plugged into its own outlet. If I try to run more than one...
Susan; # A/C units in a mobile hme is a little much to much. I'm surprised it hasn't burned down. Upping yor circuit breaker would cause an extreme fire hazard.
Jul 10, 2009 | Gibson Thru-Wall/Window Air Conditioner
Roof top air conditioner wont stay on
Clean the condenser could be tripping on high pressure switch or low pressure switch low on freon have leak fixed and recharged. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
152 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
