Question about Samsung Televison & Video
Samsung hl r5067w makes humming noise when I turn tv on , it comes from the back of set. sounds like a cooling fan maybe , picture and sound is ok
  • 231 Answers
SOURCE: HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Posted on Dec 14, 2007
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
  • 4090 Answers
SOURCE: Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Posted on Aug 01, 2009
  • 17 Answers
SOURCE: Cooling Fan noise
Another possible source for the noise is the Color Wheel. It is spinning at a high rate and the noise will get louder as it wears out. You should be able to replace the part yourself. Take a look here first: http://www.fixya.com/support/t372149-samsung_hlp4663w_color_wheel_replacement
Posted on Aug 04, 2009
  • 59 Answers
SOURCE: loud hum and then an even louder grinding noise
this is more than likely the color wheel is failing and needs replaced happens on dlp units frequently I would suggest replacing the color wheel should fix the problem
Posted on Jan 25, 2010
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
Buzzing noise in my HL-R5067W
you might be right. Color wheel can make this noise.
Jun 08, 2012 | Samsung DLP HL-P5663W 56" TV
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Feb 23, 2008 | Televison & Video
No sound or picture HL-R5067w samsung
See my TIP on my page and see if that helps u. Also the lamp could be toasted. Let me know, i may have one in stock. Thank you GURU JAY
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Televison & Video Logo
406 people viewed this question
Jerry Greenberg
Jerry Greenberg
