Question about Dryers
I have a Kenmore 80 series Gas Dryer. Everything turns and runs good. There are no clogs in the duct work. I have the back removed and the heating element cycles on and off but does not stay on long enough to dry the clothes. It stays on for about 5 sec. than turns off. It comes back on about 2 minutes later and turns off again in 5 sec. Thank you for your help.
  • 1 more comment
  • jasonb101 Apr 12, 2009
    Maybe i mislead you by saying heating element. Its a gas dryer. I can see the flames and feel the heat for about 5 seconds. Than it goes away.
  • jasonb101 Apr 13, 2009
    I have a Kenmore 80 series "Gas" Dryer. Everything turns and runs good. There are no clogs in the duct work. I have the back removed and can see the flames cycle on and off but does not stay on long enough to dry the clothes. It stays on for about 5 sec. than turns off. It comes back on about 2 minutes later and turns off again in 5 sec. Thank you for your help.
  • jasonb101 Apr 14, 2009
    Its a kenmore gas dryer
    mod # 110.74832400
    ser# mr2006833
    type dwsr-nat-1206006cv22
    These are the no's on the unit. I definetly think its the gas valve coils. Because of the intermittent flames coming on and off. If it was the igniter it wouldnt lite at all ( i would think). Can i pick this up at Sears or would it have to be ordered.. If it has to be ordered my model # is above can you point me in the right direction of where to buy this. Thank you...JJ
  • 6,784 Answers
HI, i have located a site that will have all the gas valve assembly parts that you will need to replace the failing coil assembly on your dryer. the specific coils are located on this page and, you can order from this site as well. Click the link below to be directed to the repair clinic.
CLICK TO BE DIRECTED.
Posted on Apr 14, 2009
  • Michael Masters
    Michael Masters Apr 14, 2009
    This is absolutely the coils that are malfunctioning. You are correct.
  • Michael Masters
    Please rate and god bless:)
    Scholar:
  • 192 Answers
This has nothing to do with any of the comments listed.
I;m 96% sure it is the thermal couple. This is a safty that shuts off the gas if somethings gos wrong. with out it gas could come out with out the flame , A thermal couple is not expencive, if you took the back you prop. can install the new part. once you see what the part looks like , look for the one thats there all ready , take it out and replace it the same way it was.Good luck DFD
  • 195 Answers
Dear Jasonb101,
I recommend thes site, and they should help you with part replacement. This is fairly easy to resolve and thanks for requesting me and Your Fix Ya rate is appreciated. In future just ask for jj505.
Try this :
Quick Gas Dryer Tips:
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
See this link
http://www.applianceaid.com/gas_dryer.html
Thanks
Posted on Apr 13, 2009
  • 1 more comment
  • Johnny TOLAND
    Johnny TOLAND Apr 13, 2009
    This Looks like it might be the part,but advise to give make and model to Tech.
    Thanks again. Please RATE JJ505
    http://www.appliancepartsworldwide.com/S...
  • Johnny TOLAND
    dEAR jASONB101,
    I meant to tell you it is a fault in the glow plug which is what you are seeing really get hot looking and then dies...this is supposed to glow until ignition happans ,but is faulty. Sort of how a waterheater lights..via a thermo couple insted of glow plug which heats up..and opens gas valve then ignition.
    JJ505
  • Johnny TOLAND
    See also. Thanks jj505
    http://www.applianceaid.com/gas_dryer.ht...
    Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
    Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
    Scholar:
  • 123 Answers
Hi, the problem may b due to circit breaker.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Posted on Apr 12, 2009
Kenmore gas dryer has heat, but very little...
what do you mean by a little heat?do you mean it will heat for the first 15 to 20 minutes and then no heat,if so you have bad gas coils,the coils will work normally until they heat up and then they fail,when they cool they will work again,also you could have a blocked vent line or the duct that the lint filter could be clogged with lint and has to be cleaned out.remove the vent line from the back of dryer,if it's long blow it out with a leaf blower,then remove the duct that the lint filter slides into and clean it out and vac out the cabinet that the motor is in,with a gas dryer you should do this once a year so your dryer runs good and you don't have a fire.hope this helps
Aug 03, 2012 | Kenmore 63942 Dryer
Kenmore 80 series gas dryer- 110 72842100 Dryer runs but the heat is not working? Do not hear gas igniting to create the heat, does this dryer have a pilot that went out?
Their is a flame sensor, an ignitor, and a pair of coils all wired together into one assembly.
Here is the heat control and duct fuse: themobilian_2068.jpg
Check that fuse next to that control. If it is open the dryer gas assembly won't get any power.
Manual and more good stuff HERE
Mar 27, 2011 | Kenmore Dryers
80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Mar 28, 2010 | Kenmore Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
80 series kenmore dryer not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Aug 04, 2009 | Kenmore 84052 Dryer
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Our Kenmore 80 series gas dryer won't dry clothes. The barrel turns, and the heating element appears to be working, but when the buzzer sounds on the auto dry, the clothes are still very wet. Have...
Have you checked the entire run of the exhaust vent ducting? Cleaning the lint trap is not nearly enough to keep a dryer running efficiently.
If you have any questions, please let me know. I hope this helps you.
Jul 01, 2009 | Dryers
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
No heat
If your dryer has an access panel at the bottom front remove it.  Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with  2 small blue wires going to it.    UNPLUG THE DRYER NOW    Remove the wires and connect them together.   BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked.  I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Oct 11, 2007 | Dryers
Dryers Logo
Top Dryers Experts
