Question about Garmin Nuvi 660 GPS Receiver
Can't get garmin 265wt to repeat (voice) last instructions
GPS 265 wt seems to be working well; but I can't find a way to get the unit to repeat the last spoken instructions.
5 Suggested Answers
jazzyboy11
  • 728 Answers
SOURCE: I am looking for a manual for my new Garmin GPS 265WT
You can go here and read this and even download it: http://www8.garmin.com/manuals/2675_OwnersManual.pdf
This manual includes your model gps.
Posted on May 04, 2009
  • 864 Answers
SOURCE: I need an instruction manual for a Garmin Nuvi 265 WT GPS
Manual and Quick start are available at:
http://www.retrevo.com/support/Garmin-265WT-GPS-manual/id/23123bh336/t/2/
Posted on May 28, 2009
  • 508 Answers
SOURCE: Can't get garmin 265wt to repeat (voice) last
This is a feature that i have never heard of. Don't believe there is a feature that does this, at least not on any gps i have used. Basically by the time it repeats the instruction, it is no longer valid since you have moved on. Sorry about this. Hope this helps
Posted on Jun 12, 2010
  • 1514 Answers
SOURCE: How to write adress to Favorite in GPS Garmin nuvi
  1. Press WHERE TO and type in the address
  2. Instead of pressing GO press SAVE which will be at the bottom of the screen
This will save the address to Favourites and give you an optoin to give it a name.
If you're at an address and you want to add it to favourites press the car on the map screen.
You'll get a message asking do you want to save your current location. Select YES and it will be saved to favourites.
Posted on Nov 22, 2010
How to recover an accidentally formatted Garmin 265 wt GPS?
First, the unit must be reformatted correctly then the appropriate system files put back on the unit, including the map. The map presents an issue because you simply can not copy a map from one unit to another. A map unlock code must be generated and that code is derived from the map ID code and the units internal serial number. We have repaired this problem many times. More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Oct 12, 2013 | Garmin nuvi 265WT Car GPS Receiver
Change from spainsh to english garmin 265 wt
Press the spanner symbol (Tools)
Press SETTINGS (or LOCALE if your model doesn't have settings)
Press LANGUAGE (The lips icon)
You'll see a screen with 3 icons, one for VOICE, one for TEXT LANGUAGE and one for KEYBOARD
If you need to change the voice language press the VOICE icon and select an English voice
If you need to change the text language press TEXT LANGUAGE and select English.
Oct 12, 2010 | Garmin n?vi 265WT Car GPS Receiver
Jun 11, 2010 | Garmin Nuvi 660 GPS Receiver
Registration
why am i having problem registering gramin 265 wt when enter the number it says its invaild?? whats with that is there something in java applets that needs changing
May 27, 2010 | Garmin nuvi 265WT Car GPS Receiver
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
How delete the home phone number
I can help you edit your Nuvi 265 home phone number.
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
Dec 24, 2009 | Garmin nuvi 265 Car GPS Receiver
After a map update my garmin 265 wont talk
I recommend reupdating your Nuvi 265WT with the newest firmware, and then performing the Hard Reset a second time afterwards to ensure the 'voice' functions come back on.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Oct 01, 2009 | Garmin n?vi 265WT Car GPS Receiver
Activation code for garmin 265 WT
Jeep Brainy solved the problem.
He was the second solution
Sep 06, 2009 | Garmin n?vi 265WT Car GPS Receiver
My 265 wt was working fine until 2 days ago
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
Satellite reception is one of the issues addressed in Garmin Nuvi 265WT firmware updates.
I hope that helps.
Aug 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
379 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
