Question about Toro Garden
I notice a gas leak from Toro rear bagger power lawn mower. The gas leak is from a tube located between filter housing and the engine.
  • Scot
    Scot May 11, 2010
    Need make and model #s
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
  • 143 Answers
SOURCE: Non-starting Toro lawn mower
If the mower was lying up for a time you will need to remove and clean out the carburettor and fill with fresh fuel.Stephen.
Posted on Nov 09, 2009
sisadsl
  • 1508 Answers
SOURCE: Honda lawn mower. Engine 'hunts' then stops.
cleaning the air cleaner element helps this problem also
Gav
Posted on May 07, 2010
Testimonial: "Filter now ok also spark plug so now ready to clean carburette"
hunter19_46m
  • 7482 Answers
SOURCE: my lawn mowers carburator overflow and leak gas
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
latinoboytx
  • 46 Answers
SOURCE: We need to locate the
usually there is not fuel filter.
Posted on Sep 26, 2011
Mower hit a rock and won't start
On most push mowers, there is a "key" that is located on the end of the crankshaft, opposite end of the blade, that drives the flywheel. It's a small rectangle piece of metal that connects the two. When the inertia of the blade stops abruptly, the flywheel acts as a safety for the engine, and shears the key. Tools are made to remove the flywheel and videos online for repair assistance. Replacement keys are specific to the engine you are working on. Hope this helps!
Jul 24, 2014 | Toro Super Recycler Super Bagger Lawn...
I have a toro gts 6.5hp model 20017. The enginer is overreving a lot. I had changed the carburetor and believe i put the linkages correctly, however i noticed the governor arm is rotated slightly right...
The way i set the govenor is, slacken the screw on the engine govenor arm, push the arm fully over to open the throttle wide open, now turn the actual govenor shaft within the arm in the same direction, fully retighten the govenor arm screw,
Sep 29, 2013 | Toro Super Recycler Super Bagger Lawn...
Engines dies after 5 seconds
loosen the fuel cap and try running it the vent in the cap could be plugged up
Jun 11, 2012 | Toro Super Recycler Super Bagger Lawn...
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
We can't find the engine model #or the mower ID #. We have a toro recycler
The mower ID is on the body of the mower under the plastic flap for the bagger at the rear of the mower. The engine Id should be on the front of the engine possibly on the exhaust guard screen.
May 18, 2010 | Toro Lawn Mower With Toro Power Tools
Craftsman mower gas leaks into air filter
overhaul the carby , paying to something holding the needle off the seat and flooding the engine
Jan 28, 2018 | Toro Lawn Mower With Toro Power Tools
Garden Logo
382 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
