Question about Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER KFC-2505 Car Speaker
Kenwood audio equipment
Where can i sell my kenwood KAC-929 and 2 KFC-W2505's in box? and could anyone estimate how much this would be worth?
There worth from 35 to 80$ per speaker ! plus the box. I've got the same ones 2x10 in a box and never had a problem. If I did it was always with the power amp settings. Remember the speaker specs when setting up the amp. otherwise sell them quick on ebay or your local cash converter shop.
Posted on Feb 24, 2008
  • 752 Answers
If it was mine i'd want $200-$300 if in mint condition. Try a classified in the local paper or online ads.
Posted on Sep 22, 2007
My kenwood kac-929 amp is melting my ground cable help
That amp needs 4 gauge power and ground wire minimum. Too small of wire is just like using too small of a water main to a house....it's just not gonna work out
Jun 05, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Won't drop with beat
Sounds like the speaker is out of phase. Check your speaker connections. + to + and - to -. Or red to red, and black to black.
Apr 11, 2010 | Kenwood KFC-W2505 Car Subwoofer
I NEED USER MANUAL OR SPECS. TO BUILD PROPERLY SIZED CABINETS
Can't help you on the manual, but basic specs for both drivers are listed on crutchfield.com web site.
Easy way to do it is ; type in KFC-W2505 and the KFC-W2509 in your search engine and click on the Crutchfield web site. This will give the overall cubic dimensions of the cabinet, plus other info. Hope this helps...
May 02, 2009 | Kenwood KFC-W2505 Car Subwoofer
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
No sound from my woofer
Check your speaker connections... try using a multimeter set to "OHMS" and see if the speaker is reading around 4-8 ohms... if it shows no reading there is no continuity in the coil of the speaker
Mar 24, 2009 | Kenwood KAC-929 Car Audio Amplifier
Diamentions off subwoofer box for 600watt in meters please
You need to know the speaker travel distance (excursion) and a few other numbers from the maker of your speaker, then you can plug those numbers into a box calculator. Just the wattage isn't enough to know.
Also, you will get different numbers for sealed, ported, and bandpass boxes, so you need to know which type you want ahead of time.
Mar 16, 2009 | Kenwood KFC-W2505 Car Subwoofer
Kenwood KAC-X1R and one 12" Kenwood KFC-XW1222D at 1 ohm blow out.Why is that happening?
You may have a high resistance in your positive or negative power supply. with your amp you need to use at least a 2 gauge power cable. Is your fuse blowing? if so then a short circuit to ground may be causing that.
Good luck
Aug 01, 2008 | Kenwood Car Audio & Video
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-929
From the Input of amp, just connect cheap speaker with wires to input of amp.
If you have sound from speaker, most likely the amp is bad or loose connection.
Dec 25, 2007 | Kenwood KAC-929 Car Audio Amplifier
Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER KFC-2505 Car Speaker Logo
194 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
