My GE front loader washing machine won't drain the water out. Most times clothes are sopping wet when it 'beeps' as if done with the cycle, while still showing 18 minutes left, yet the machine 'beeps' and the door unlocks leaving soaking wet clothes, sometimes with large amounts of suds on them. Thanks for any help!
  • 15,935 Answers
It appears your timer/main controller/CCU or pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Clothes are sopping wet even after doing the spin cycle 3 and 4 times, water is going through hose fine it seems, it a front loader
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Kenmore Energy Star 44092 Front Load...
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
There is still water in my washing machine drum when it is done
Is your drain hose to far down the drain pipe?
Sometimes the water can cyphon back down into the machine if this is the case.
Jun 17, 2009 | Frigidaire FTF2140E King-Size ENERGY STAR
On one wash clothes came out sopping the next there was no water
Check the drain hose for kinks or blockage. The drain hose should be free in the drain pipe so air can get around it. The drain should be good enough to accept a lot of water all of a sudden without overflowing.
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Are you supposed to see the water level?
they dont take alot of water..thats one of the good things about the new machines like that. they use only what they need to do the laundry and thats it.thats why they call them so efficient
Jan 21, 2009 | GE WBVH6240F Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
