With a vacuum pump, pull a deep vacuum on the system then charge the refrigerant in. It will go in by itself with the system under a vacuum.
You can also remove the wire connector going to the pressure switch on the accumulator and jump it out with a small wire. While the car is running and the switch set for cool the compressor will come on.
I left a open can of refrigerant hooked up to the system (a/c off) and went in the house to eat and when i came back i started up the car and turned the A/C on and it was working. Evidently. i should have waited for a while to let the refrigerant enter the system.
