Question about Dell Optiplex GX110 (2909T) Motherboard
My problem that i can uprade my SDRAM 128 to 512
  • 433 Answers
You can use PC-100 memory up to 512MB max (2X256MB)
Posted on Apr 30, 2009
  • 20 Answers
You also have to make sure that your pc is able to hold 512 mb of memory. And whether or not you need to get 2 256 MB modules or just one 512 MB module. This can easily be looked up on line from a google search engine or others.
Posted on Apr 24, 2009
  • 449 Answers
Hi, check to make sure the sdram is compatible with the computer system if not upgrade can not be possible.
Posted on Apr 12, 2009
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
Dec 29, 2010 | Dell Inspiron 1525 Notebook
I need to know what RAM I should use in my Compaq Presario 5000 desktop computer
You have three Ram Memory slots.
EACH ram memory slot's maximum amount is 256MB
Total Maximum Amount for the computer is 768MB.
Uses SDR Sdram ram memory.
[Single Data Rate Sdram. Commonly just referred to as Sdram.
That is a misnomer.
All ram memory from SDR to DDR3 IS Sdram.
Synchronous Dynamic Random Access Memory.
SDR Sdram = Single Data Rate Sdram
DDR Sdram = Double Data Rate Sdram
DDR2 Sdram = Double Data Rate 2 Sdram
DDR3 Sdram = Double Data Rate 3 Sdram
Just thought i would share ]
Uses SDR Sdram that operates at a frequency rate of 133MegaHertz. (133MHz)
Also known as PC133.
Make sure it is,
A) Non-Buffered
B) Non-ECC
C) Low density
D) CAS Latency of 3 (CL3)
E) Uses 3.3 Volts
Here's an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=423457&CatId=828
One more,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146303
For questions post in a Comment.
Regards,
joecoolvette
Dec 08, 2010 | Compaq Presario 5000 PC Desktop
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
Having trouble located ram for my comptur
It's SDR Sdram that operates at a frequency rate of 133Megahertz.
(133MHz)
Commonly known as PC133.
(SDR stands for Single Data Rate
SDR Sdram is commonly just referred to as Sdram.
A slight misnomer.
ALL Ram Memory from SDR Sdram to DDR3 Sdram, IS Sdram.
DDR Sdram?
DDR2 Sdram?
DDR3 Sdram?
Double Data Rate 3 Sdram)
Should be low density, unbuffered, Non-ECC, and have a CAS Latency of 3. (CL3)
Ram Timings of 3-2-2-2, and a DRAM configuration of 16Meg X 64 for a 128MB ram memory module
Voltage is 3.3 Volts
From sources, it's indicated that the Total maximum amount is 256MB, but sources could be mistaken.
Two ram memory slots, that for EACH slot the maximum amount is 128MB.
(I'm thinking the total maximum amount should be at least 512MB's)
You might try these guy's,
http://www.crucial.com/store/listparts.aspx?model=300%20Series%20%28SDRAM%29
If possible I would call them to confer first, and have the model number from the back of the computer handy.
Aug 08, 2010 | Gateway 300 C PC Desktop
What Ram to buy for 1.2 GHz Intel celeron Compaq 5000 desktop currently with 256MB of RAM
You have to purchase SD RAM how much? depends upon the BIOS. Kindly let me know the bios version for accurate solution.
Jun 13, 2010 | Compaq Presario 5000 PC Desktop
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Dell Optiplex GX110 (2909T) Motherboard Logo
138 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
