Question about Samsung 37 in. Flat-Panel LCD HDTV
No signal on teristeral but able to watch tv through sky
  • 325 Answers
This could be down to several things so sorry if this is long winded but really needed more info from yourself...
Sky gets its signal from the dish mounted on your exterior wall.
your terrestrial signal comes from your terrestrial aerial be it external or internal.
If you do have an aerial cable coming into your property and it is connect to your television. Go into your TV MENU and set it away on Auto Tune if this does not come up with any channels. Try auto tune on your built in Digital tv ie DTV if it has this option...
If neither of these work then you need a new aerial or it needs to be re-aligned.
Personnally I would not bother with a Terrestrial Aerial You already have Sky installed so this will be fine for when the Whole of the UK goes digital. Dont be fobbed off by people telly you that you need a Digital aerial as your sky dish is already Digial anyway.
Hope this Helps
Little Dish Fitter
Posted on Sep 14, 2009
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
Tip
Watch your SKY channels on a second TV with Magic Eye and remote
If you have Sky Multi-room this will feed a separate SKY signal from your LNB on your dish to a second SKY box if you have the basic this will not cost you anything you still need a card inserted in the front to make this work. I think it costs £5 extra for more channels.
So if you have SKY + you will have 3 coaxial cables coming out of your LNB. ( 2 for the SKY + and 1 for the Multiroom )
To ger the signal for free the easy way is to connect a coaxial cable from the RF2 output on the back of the SKY ot SKY+ box into another TV and use a SKY Magic Eye these cost about £5 and have a range of about 20 meters. You can use a coaxial splitter to feed two TV but you will loose more signal the more you connect.
You will need to turn this function on using the hidden menu to allow you to use the Sky Remote control then LED on the unit will show you that there is a signal.
Press <SERVICES> <4> <0> <1> <SELECT> and goto the RF2 output to turn the signal on you might find that this signal is already turned ON for you.
Note: If you are using a multiplex faceplate unit this signal will not work as it relies on continuity of the coaxial cable with a 12V DC signal being sent out of the back of the SKY Box.
For all setups changing you Box model or adding an extra box SKY must to this for you by having your phone line connected so they can reprogram your Smart Card.
on Jan 30, 2010 | Audio Players & Recorders
No signal
hi do you have another tv in the house you try, see if this works
then you know the aerial is sending a signal, reconnect your main tv go into the menu select auto tune hope it helps
regards
shaun
Dec 07, 2013 | Panasonic VIERA Televison & Video
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
I have recently bought a sky plus hd box and want to connect an external dvd recorder to it(Sony). Followed instructions but it will not pick up a signal from the hd box by the way I live on the costa del...
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu.
Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
Nov 20, 2009 | Televison & Video
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
LG 42 inch Plasma Picture in Picture with SKY satellite service
PIP only works off two seperate signals, eg you cannot watch 2 sky channels at a time, you can watch sky tv and then your analogue channel using PIP or freeview, you can then swap which is to be viewed as a large picture and which is to be viewed as the smaller picture or half and half.
Sep 07, 2008 | LG MZ-42PZ14 42 in. Plasma Television
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Samsung 37 in. Flat-Panel LCD HDTV Logo
384 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
