Question about Kenmore 22422 Top Load Washer
Kenmore 8 series Top Load Washer Heavy Duty
The motor is running, but it will not spin.
  • 60 Answers
Betwen the motor and the transmission there is a drive coupling made of plastic and rubber in between the 2 plastic drives that is your problem replace the drive coupler and let me know how you make out
Posted on Sep 12, 2007
SOURCE:
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty series 80 model 110.25842400 will not spin.
if it will not drain or spin it is a bad lid switch,if it drains but will not spin it is the motor coupler,tip it back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 22422 Top Load Washer
My washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Oct 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Doesn't agitate or spin. Motor runs
model number not found. If it is a direst drive model you need to see www.youtube.com/watch?v=WLPGs2UMUJc
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
90 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
