Question about LG LSC26905TT Side by Side Refrigerator
ICE DISPENSER DROPS ICE BUT ICE WILL NOT COME PAST DOOR FLAP INTO GLASS HAVE TO MANUALLY LOWER FLAP TO RELEASE ICE TO CUP I need to replace the ice maker flap solenoid in a LG lsc26905tt frig. how do I get to it without damaging the plastic trim on the door?
    Sergeant:
  • 291 Answers
there is a spring on the ice door/crank door recess. There is a Solenoid assembly in the dispenser,
icemaker  have the panel on them that pops off,remove this slowly,you can then unscrew the board panel to get to the solenoid,the solenoid has a arm on it that engage's the solenoid,most of the time the solenoid's have rusted and must be replaced.
click this link for more detailed help with pictures http://www.popularmechanics.com/home_journal/home_improvement/1276061.html
.please do accept the solution.thank you for using fixya. keep updated.
Posted on Apr 12, 2009
The ice flap on my freezer will not stay open. If I reach up and grab the flap as it's opening, the ice will flow freely. But if I don't grab the flap and keep it open, the ice won't dispense. It's no
Kristen,
Thank you for giving more information. I believe you will need to replace the flapper on the ice dispenser. I based this answer on the following: you mentioned when the door is held open ice comes out. Let me know if this helps. As you may know, there are several different things that could cause this issue, but this is the most common one of them. Here is a how to video on this type of repair:
Jul 21, 2014 | Frigidaire Refrigerators
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LSC26905TT Side by Side Refrigerator Logo
101 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
