Question about HP DeskJet 842c InkJet Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
When printing, printer either spits out all blank pages, or all middle pages are blank (2-4 of 5 pages are blank, first and last print ok sometimes)
  • 1 more comment
  • shorsegirl24 Apr 12, 2009
    I have uninstalled and reinstalled, but unfortunately it didn't resolve the problem.
    I have checked all the settings, and they appear normal.
    The printer is set as default.
    It is not just for one program, it won't print in Word, or Explorer.
    I tried resaving my Normal.dot, and that didn't work either.
    Ugh!!! Thanks for trying!
  • lasertek Dec 29, 2012
    Visit my blog and see basic troubleshooting HERE
  • Alaskabobb Dec 03, 2013
    I have Win 8.1and psc 2210 all-in-one, mine did the extra page thing until I disabled "allow manual Duplexing" in "Device settings" in "printer properties" not the regular properties at the bottom of the right click window, but "printer properties" half way up. way up.
    New Friend:
  • 39 Answers
1. Try cleaning or replacing your laser scanner mirrors.
2. Make sure that your transfer roller is seated properly.
3.Update your printer driver.
4.You might have failing power supply, make sure that the drum ground spring is connected to the engine controller board properly. You can also replace your high voltage power supply.
Hope this helps.
Posted on Dec 29, 2012
    Sergeant:
  • 199 Answers
Hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Posted on Apr 12, 2009
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
My HP Photosmart printer was printing just fine until I had to change ink cartridges. Now it won't print anything, it just spits out a blank page.
Sometimes your printer print blanks pages, if your printer is out of ink. You can check the quantity of ink in the status of the printer. Sometimes, your printer displays messages if it is out of ink. So if you are facing such issues, you need to refill the ink in your printer. Communication problem with the printer and computer is also a reason for printing blank pages.
Jan 03, 2011 | Office Equipment & Supplies
Printer prints blank page
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
Ricoh CL3500N - not printing all characters on the page
It might be a print driver problem. I think there several different drivers. Go to Ricoh-usa.com and download all the drivers for the operating system you are using and try them. If there is a rpcs driver that might be your best bet.
Apr 24, 2009 | Ricoh Aficio CL3500N Laser Printer
Printing only upper part of page - big graphic PDF
1: check in the printer properties( page setup ) is it latter then make it A4
2: clean the roller
3: also when u printting check with uper try not from try 2
if its printing proper then try is touching roller
Mar 25, 2009 | Canon PIXMA MP540 All-In-One InkJet...
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
James
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
PRINTS BLANK PAGES
dear sir your computer data is full you need extra ram or you should delete un necessary data there is no problem with your printer its only happening because of your system
Sep 22, 2007 | Brother MFC 7420 All-In-One Laser Printer
HP DeskJet 842c InkJet Printer Logo
15,600 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
