Question about Dewalt dw3988 14tpi portable band saw blade - 44-7/8", .025" - 3 pack
My center piece on the table will not line upor go back into the table top of my Delta 14" Bandsaw when I use a bigger blade. What should I do to correct?
    President:
  • 1,996 Answers
Can you turn it 180 degrees so the slot faces the other direction?
If not, (because of the notch), you'll need to readjust your guides...You probably should anyway..
Begin by backing off the bearing behind the blade that keeps the blade from riding farther back into the outfeed table. Then loosen the guide blocks and adjust the upper wheel so that when the blade tracks on the tire, the cutting edge is just forward of the center of the tire, (where the cutting edge of the narrow blade tracked). Once you have the blade running smoothly, bring the guide blocks in close to the sides, and adjust the back bearing so it just barely spins when the blade is freewheeling, and provides support when a cut is made.
You may have to adjust these instructions slightly to account for what's available with your saw, but that's basically the method for making the blade track in the center of the knockout.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 13, 2009
  • efs_perpends
    efs_perpends Apr 13, 2009
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
I'm looking for a table top band saw that will cut 4140 and harder steel, what kind of blade and saw would you recommend. ?
i have a great company for you to contact to find the perfect blade for your needs. go to www.doall.com and click on the doall sawing tab and find the customer support phone number. call them during business hours and you can get at blade tech on the phone that will ask you a few questions to what saw you have and what your cutting and they can put you on the perfect blade. i use them for a bandsaw we use at work, we manufacture awnings and signs. i get all my bandsaw blades from Doall
Dec 24, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
My delta 28-274c bandsaw has started to track off-line when I use a fence aligned with the guide slot in the table. What are the possible causes and solutions?
Peter,
This is a common characteristic of modest sized band saws. If the problem has been increasingover time with everything the same (same blade, same tension, same height adjustment, same guide bushing settings, same material) then it's time for a new blade or resharpening, or at least a good blade cleaning. However, you might be able to improve things by increasing the blade tension. Or you might use a blade with bigger teeth when cutting thicker material. If you have to push pretty hard to make the cut, it could be dull, or the blade has too small of teeth for the material you are cutting. Lots of teeth in contact, means you have to push harder to get the right pressure on each tooth, which means more blade deflection. Plus the gullets (space between the teeth) might be too small to accommodate enough sawdust. good luck
Oct 07, 2010 | Garden
In the Market for a better Band Saw
Everybody wants to resaw, but the only saw I've seen that will do it is a resaw, they are big, powerful machines. I have an old delta 14, with an aftermarket 1 hp motor, trying to resaw is a nightmare. I don't try anymore. Jet makes a big resaw, so does grizzly, both Taiwan machines, what isn't>? But they work. If you are lucky enough to find an old bandsaw with 36 inch wheels and a ten HP motor, that would be nice, you could resaw whole cars in that thing.!I The $300 special might be worth getting and customizing to work, You would need a big blade, about 1 inch min, and a bigger motor, say 2HP min, Then hope that the tracking system will take the heavy cuts. When I have to slice something , I do it first on the table saw, cut both sides, then run it through the band saw at its max cut, 6 1/2 inches, then plow it through the planer. Always a way around this stuff. Hope this helps.
Mar 01, 2010 | Ridgid 14" Band Saw with Stand
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 | Delta Saws
I need a manual for an old Sears Band Saw Model #534.01120
Does it look like this? Unfortunately, they don't have a manual that I could find. But you might like to post your request in the forums there, as they get some traffic from aficionados of old tools with wile and know how.
It might help you also to google Dunlap & PowerKing for the manual.
As far as tuning it up goes...
Check each of the wheels' "bearings" to begin with, to ensure they are running smoothly and as true as possible, without end play or wobble. Then use straightedges and flat jointed boards to line up the three pulleys as much in a single flat plane as possible, by shifting shims, etc. (It may behoove you to remove the table out of the picture to begin with, if possible, so you can get the wheels lined up well with one another, then replace the table once the blade will track.)
The adjustments on a three wheel system can be a little more delicate and temperamental than on a standard 14" bandsaw, so be moderate in your tracking adjustments, and crank the wheels by hand to begin with as you work the tension up on the blade, checking constantly to keep the blade running as close to the center of all three tires as possible. Don't worry about the blade guides at all until you get the blade running on the wheels well. Then move the backed off guide blocks and backing bearings into place. They are meant, after all, to keep the blade from deflecting, not to force it into position.
That's my quick advice for how to tune it up.
Good luck. It looks like a beaut!
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 22, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
When making a straight cut with my bandsaw, the blade will
Before tuning it up, loosen the guides and wheels away and square the table to the tensioned blade. Then follow these steps in order:
  1. First, adjust the upper wheel so the blade is tracking at the center or just to the front of center of the wheel tire. (You can see this with the cover removed, and adjust it with the nut/wing nut in the back).
  2. Now, make sure the blade guides are adjusted so they don't deflect the blade to either side (when looked at from the front), so they contact the blade just behind the gullet of the teeth, but not against the hooked teeth themselves, and are just tight enough to allow the blade to run freely (including the weld). (If your guides are worn and out of flat, you may wish to dress them on a sander before adjusting them against the blade.) Adjust the guides both above and below the table. At this point, ensure that the guide bar moves up and down easily and locks into position without torqueing the guides against the blade.
  3. Finally, adjust the bearings behind the blade, so they just kiss it, and turn freely when you revolve the bandsaw wheel. They will support the back of the blade when pressure is applied against it during a cut, and help immensely to keep the blade tracking straight.
At this point, check the cut by trying to follow a straght line penciled on a board. Some blades will naturally tend to veer slightly on a diagonal, depending on how they are sharpened, and you may have to adjust your fence to compensate for this "drift".
But if you follow the steps outlined above, and have a good sharp blade to begin with, you should be able to split a line.
If you follow these tips and they prove helpful, please let us know your problem is solved. Otherwise, give us a little more detail and someone will be happy to follow up.
Mar 20, 2009 | Delta Saws
Dewalt dw3988 14tpi portable band saw blade - 44-7/8", .025" - 3 pack Logo
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
