My aggitator wont stay down to wash clothes we have to hold it to work
My maytag washer aggitator is not staying down its coming up and not pulling clothes down to wash them unless we hold it
  • Washing Mach... Master
  • 3,361 Answers
There is a 1/4 inch hex head bolt on the side of the agitatot that has loosened. Tighten it.It is just above the lower agitator vanes.
Posted on Apr 12, 2009
There is cloth stuck under the aggitator on my Capacity plus Admiral washing machine. Model #lnc6766B71 how do I remove the aggitator
As a general rule Admiral is a VERY inexpensive machine, so you may be better off with a new one if the parts prove expensive. MAKE SURE TO UNPLUG MACHINE.. Be careful the agitator doesn't come loose suddenly when you are removing it, I have seen more than one bruise on the face from this.. hold your head to the side when pulling it off. http://www.rakerappliancerepair.com/NephewClub/Diagnostics/Washers/Maytag/Maytag%20TL%20Bulletin%20TDL-0086-B.pdf
Jul 06, 2015 | Admiral Washing Machines
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune smells very musty. I have used vinegar, baking soda, and bleach but the smell wont go away!!!
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
The aggitator in my Hotpoint Washer just came off while it was washing clothes. I thought I had it back in but it came back off on the next wash. How do I get it to stay?
hi .sometimes the problem is with the bell which is located under the agitator. its a part that holds the agitator down. or the agitator its self. the bell is cheap to replace first. thanks the appliance doc please rate me thanks
Oct 01, 2008 | Hotpoint Washing Machines
Agitator
there should be a 7/16s bolt under the cap try tightening that up
Mar 21, 2008 | Washing Machines
Maytag Quiet Plus 2 cloths washer - aggitator drain plugged up
Ok grab hold of the top of agitator about 4 inches from the top and just pull that top right off.Hit it at an angle and it will pop right off .Dont be shy ,its just plastic that is snapped onto plastic.To put it back on just line it up on top and Smack It back on.Easy Ha???Youll be able to clean it alot easier now.If you dont use fabric softener your problem will be gone for ever .Try using less and mix water in it first.I'll help you if you need further help..
Feb 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
