Question about Honda 8 HP Engine
Honda powered gx160 model pressure washer wont start
How do i get my honda powered gx160 model pressure washer to start. i havent used it in about 2 years i recently took the plug out and cleaned it but still nothing. any and all help is greatly appreciated.
    Problem Solver:
  • 15 Answers
Did you drain out the fuel before you stock it? If you didn't, you may need to clean the carburetor or replace a new one because the fuel inside has become a kind of stick varnish. You may take a look at following link to see how to change or replace a carburetor. http://solosmallengine.blogspot.com
Posted on Jun 08, 2012
  • 10,865 Answers
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
Why does the Honda GX160 engine start to pulse after running pressure washer for a few minutes then finally kills?
Hi pulsing is usually a sign of insufficient water flow to the unit.
always get the largest water hose you can for the feed and check to see if your water system can keep up (if it is a three gallons per min machine grab a bucket and make sure you are getting at least 3 gallons per min before you plug the machine in.
The number one culprit for bad flow is the ez hoses or retractable hoses.
Sep 21, 2014 | Garden
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
Apr 23, 2012 | Honda Horizontal Engine 5.5 HP OHV 12V ES...
I'm Looking for the engine manual (NOT operation
Thanks for choosing FixYa,
The engine should be a Honda GXC160 5.5 Hp.
GO to this website and download your manual:
http://engines.honda.com/parts-and-support/owners-manuals/gx160
You will need your serial number.
If I got the engine model number incorrect choose the owners manual link on the left side of the page and enter your model number.
Kelly
Aug 18, 2011 | Garden
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Apr 08, 2010 | Northstar Pressure Washer 3000 PSI
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Honda 8 HP Engine Logo
1,725 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
