Question about Whirlpool Refrigerators
What would cause the metal face between the doors of a side by side to be extremly hot to the touch?
  • afewcrowns Apr 12, 2009
    Where whould that switch be located? I have both Fridge and freezer set on normal. Could it be the door seal is bad? It is 13 yrs old, never had any problems with it. Thanks so much
  • Whirlpool Master
  • 3,361 Answers
A condensation heater is located in this panel to prevent moisture from forming.
Some refrigerators have a energy saver switch that when selected will turn this heater off.
Posted on Apr 12, 2009
  • steve
    steve Apr 12, 2009
    ("IF") there is a external energy saver switch, it would be next to the temp control. There may not be a bypass switch on your model.
    What is your wxact model number?
My fridge is working but to touch the outside it is extremely hot to the touch. What would be wrong with it?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 07, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My frig is extremely hot to the touch on the metal face that separates the freezer and frig. Any thoughts on what might be causing this problem. If it helps, we just moved the frig from another home. ...
Likely the cooling fan has died. This happened on my unit. The fan is visible from underneath on the rear left side. Use a flashlight to see if it is spinning. I used a broom handle to tap it and it started to run, which cooled the metal you found hot. I ordered the part on line and replaced it. Heating problem went away.
Jul 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Interior wall of unit gets extremely hot
If you are talking about the wall that runs between the freezer and the fridge where the door gaskets actually touch. The answer is no. It should be warm though.
What can cause this is the fan that is located at the rear not operating or dirty coils under there. Check the fan it should be operating when the unit is in the cool cycle, if it is not then it will need to be replaced. And clean the coils. This will help.
May 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I don't know the model number but our refrigerator is approximately 6 years old and is a side-by-side model. My problem is that the metal frame that separates the two compartments which touches the rubber...
Usually when the outside of the refrigerator is hot, there is some problem in the refrigerant cycle. I suspect that if you reach under the refrigerator and touch one of the coils, it will be very hot, too.
First, look at the coils and see if they are dirty. If so, clean them good. Second, the compressor should be running properly (I assume it will be.) Third, make sure the compressor fan is turning. If this fan doesn't operate properly, the heat in the compressor coil will not be removed and transferred to the room air. It certainly sounds like the heat is not being removed from the coil since it is so hot.
If the compressor fan is not turning, you will likely have to replace the fan motor.
Oct 19, 2009 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
