Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Amp only has red thermal light on. some times the
I have a rockford fosgate T3002 amp. It only has red thermal light on. some times the subs work and some times they dont. When they do work they sound terrible.
  • 102 Answers
Please review your wiring, both INPUT and OUTPUT
Posted on Apr 12, 2009
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
Rockford fosgate p4004
You need to check the ohms on your subs an amp . try unbridgen the amp . Go to Rockford Fosgate dot com on the amplifier wiring diagram hopefully that helps 6_28_2013_8_51_12_am.jpg
Jun 18, 2013 | Audio Players & Recorders
Water spilled on rockford t3002 now protect light is on is amp repairable
All depends, when amp is connected does it blow the fuses, if not, it maybe repairable, But its a long process. when your amp is on and has water spilt onto it, the water inside the amp evaporates and gets into every nuck and cranny due to the amp heating up when powered on. you need to strip amp down to bare basics and completely dry the circuit board and all compnents one by one, hense a long process. Best thing to use is a hair dryer. get the hair dryer into every nuck and cranny, into the connectors, basically everything. once done. put back together and try it then. i had a home amp with water damage and fixed it this way.
Mar 03, 2011 | Rockford Fosgate Power T3002 Car Audio...
I have a t3002 going to a L7 12" sub. it played for bout 5 minutes down my road then no sound. the protect light is on. Y?
It could possibly be a bad ground. I ran in to the same problem the other day, but I wasn't driving. Started my car and everything seemed to work ok then all of sudden nothing. I checked all the voltages when the car is turned on, remote turn on (should have more than 11v), power cable to chassis ground (12+ V), they were all there. Then I finally checked the ground just moving the connection turned it on and then off. This occured repeatedly, then I disconnected the ground and then reconnected, now amp is running like a champ.
Oct 02, 2010 | Rockford Fosgate Power T3002 Car Audio...
The thermal light on the amp is on and the sub doesnt work
if you are in the Tallahassee,Fl area call 850-339-1130 -Capital Audio & Electronics Repair we repair all namebrands & all models
Mar 19, 2010 | Rockford Fosgate Punch P4002 Car Audio...
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
My amplifier is a t3002 keeps burning the fuses
I have a 900 watt punch that wont keep any fuse i put in it and need help badd! Its not my wirering cuz i have another amp in there now but its nothing even close to my baby!
May 24, 2009 | Rockford Fosgate Power T3002 Car Audio...
Left positive speaker input stopped working
try swapping over the rcas for instance if black is in r and red is in l then swap them so red is r and black is l
if that doesnt work try swapping the subs over to as you may have a faulty sub. if that doesnt work then check the fuses on the amp
still no joy then i would suggest taking your amp to your local car audio dealer and getting them to have a look at it
Hope this helps if so please dont forget to rate
best wishes
Upfront Audio
Apr 23, 2009 | Rockford Fosgate Punch® 450.2 Car Audio...
Only thermal light on.
check rca and make sure u have right input to amp and speaker
Apr 12, 2009 | Rockford Fosgate Power T3002 Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
471 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
