GE JTP85 Electric Double Oven
Problem for GE JTP85 Electric Double Oven
Turntable not turning
By boris1 on Sep 11, 2007
My turntable on my microwave is not turning. It turns manually but not when the microwave is running. If the turntable is not turning the microwave will not heat.
Same Problem
Jan 22, 2009
-   I have the exact same problem mentioned by these other folks - the turntable won't turn and the over will not heat.-   Guest
Nov 05, 2008
-   Microwave will not heatand turntable not turning -   Guest
Apr 05, 2008
-   the turntable not turning and it is not heating the food or water but everything is working beside that-   sc2428
Mar 09, 2008
-   The lights are turning on,time is coming down but the turntable does not rotate and is not heatig.
-   Guest
Dec 16, 2007
-   Turntable is not turning, and not heating. Lights are working, the fan seems to be working, everything else looks as it should be working. Oven is clean.-   Robert25
Solution #1
posted on Aug 21, 2009
Not Rated)
karlet
Rank: Guide
Rating: 0%, 0 votes
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Was this helpful?
Yes
No
Popular Solutions for GE JTP85 Electric Double Oven
Questions and Unsolved Problems for GE JTP85 Electric Double Oven
Do you recommend GE JTP85 Electric Double Oven?
Answer
Answer
microwave door sticks. if I press and "hold" the door release button, the door will open.... (More)
Answer
Im smelling a burnt smell in microwave The carousel is spinning slow
Answer
I have the same problem. I've just replaced the membrane touch pad for the 4th time. This time, the... (More)
Answer
My GE 27" JKP77WV got very slow reaching even 330 F. It cannot reach 500 F ; I did calibrate... (More)
Answer
I need the wiring diagram for control panel WB27T10297 for GE Profile Built-in Double Wall Oven... (More)
6 Other Users Have The Same Problem - Continued
Comment by bwikse, posted on Nov 09, 2007
1) Last 6 months - turntable would run with door open but heated fine.
2) Last week - table would turn intermittently when trying to cook. If table did not turn, micro was not heating.
3) Yesterday - Pad operates normally, sounds like it is operating, but table does not turn and micro is not heating.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
