Question about Kenmore 22422 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Kenmore 240 series top loader drain will not shut to fill with water,water goes right down the drain,works sometimes.thanks in advance
  • Kenmore Master
  • 3,361 Answers
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Posted on Apr 12, 2009
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 70 series top loader - wouldn't drain & spin
The lid switch is the only thing affecting this part of the cycle. The new switch comes with the new plug (under console ) and the harness that goes to the switch. The console will flip up and the cabinet will pull forward after removing 2 brass looking clips. After that it's right there under the right side of the upper cabinet.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 80 series washer and it won't fill up some times
It sounds like a siphon issue so nothing should be broken.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
236 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
