Question about Panasonic Lumix DMC-FX7 Digital Camera
Doesn't acknowledge memory card?
Hi- i have a dmcfx07 camera that doesn't like the memory card i have (it is a panasonic memory card that is the right size for this camera). How do I set the camera to save to the memory card? it appears to be saving to internal memory (which only holds about 3 pics). Help!!
    Scholar:
  • 33 Answers
I suspect your memory card is damaged. If it is new, return it. If you can find a computer or printer with a slot for that type of memory card, see if the computer recognizes it. You may be able to repair it by using the computer to format the card. Usually you right click on the card's icon in My Computer and choose to format. This erases everything on the card and makes it ready for use.
Posted on Sep 11, 2007
SOURCE:
Says memory card protected when I try to use it
If card lock button isn't faulty and doesn't free by sliding it a few times does your camera have a memory lock function in the menu?
Sep 27, 2012 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon PowerShot SX20 IS Digital Camera freezes when importing pictures
Try downloading the current software for you model from the Canon site. You could try inserting the memory card into the card reader on your computer and if you get the same result then it would appear to be a software problem that you use to download. Sometime conflicts appear.
Nov 01, 2017 | Canon PowerShot SX20 IS Digital Camera
My camera says memory card protected how do i take this off
Eject memory card and flip the white switch. If that doesn't fix problem some cameras can add accidental deletion protection which first needs to be disabled
Jun 07, 2012 | Panasonic Lumix DMC-G1 12.1MP Digital...
I need a user instruction manuel for my Panasonic DMC- FXO7 camera
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Sep 05, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
My new 4g memory card will not let me use it, say memory error
Hi there!
Since this is a new memory card, the first thing that you can do is to format the memory card through the camera menu.
If that doesn't work, try another memory card. If that card doesn't show the error then your new memory card is the problem.
Hope this helps.
May 14, 2011 | Cameras
The memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card.
May 12, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
Screen says ' this card is memory protected'. same card in my lumix DMC-TZ1 for years. do cards fail?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't work, try a different card.
Yes, memory cards can fail. Run one through a dishwasher, for example. With normal use, cards shouldn't fail for years, but exceptions happen. You should always have a second card. Would you drive a car without a spare tire in the trunk?
Mar 24, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
Mar 01, 2010 | Pentax Optio M20 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
64 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
