Question about Garden
Vantage Super B petrol lawnmower won't start. Can't detect any spark at the spark plug. I have cleaned the contact points on the electrical motor, and spark plug itself but still no spark!!
5 Suggested Answers
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
  • 57 Answers
SOURCE: I have a lawnmower with a BSA 3.5 engine
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Posted on May 15, 2009
vincob
  • 718 Answers
SOURCE: lawnmower wont start
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Posted on Sep 26, 2009
Which way do I tilt my efco lawnmower to clean without mixing oil and petrol it is model LR53TBX ?
You;re usually safe if you tilt it so that the cylinder (spark plug) is kept at the highest point.
Mar 08, 2015 | Garden
I have a kohler HU600F in a push style lawnmower that has no spark
how old is this coil contacts or you talking about points
Sep 03, 2014 | Husqvarna Garden
Starting problem with admiral 16SE Petrol lawnmower
lack of fuel
possible water in the unit or blocked main jet
have the carby overhauled
Feb 08, 2018 | Admiral Garden
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
Will not start. Been sitting since 1980.
hi, the cylinders are dry of petrol fumes and you need a (good battery), if all the mehanical parts (working fuel pump and clean fuel filter) o.k. and the spark plugs are clean and the (spark plug timming leads) are correct and points are set and the (ignition coil) is o.k. this engine should start. (if not) take off the air filter and check it is clean, leve the air filter off and put a very small amount (egg cup full) of clean petrol into port the carberreter (it will not start straight away because the plugs may be wet) or wrong (timming leads) if it splutters problebly not enough petrol or ignition faults (electrical points contacts dirty) all cars need metered fuel and air to run. wish you luck gerry
Sep 07, 2010 | 1980 Cadillac Eldorado
CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Apr 14, 2010 | Garden
Hi, Honda HRG465C Petrol Mower running problem
The first thing to check is the spark plug, is it clean and properly "Gapped" next is are we actually getting spark, does the spark plug actually "Spark". Check. Check Spark Plug lead., Check connections. Do we have Fuel, Check .and Is the fuel getting to the Carburettor? Check. Check the battery. alternator, generator, is providing power. Check the Mixture.
Mar 23, 2010 | THQ The Lawnmower Man
Electrical problem with my 1999 Scotts Riding Lawnmower
If the motor is trying to start but won't try removing the engine shroud and cleaning the magnets on the fly wheel and the two little prongs close to the fly wheel. They might just be rusted and not getting a good electric pulse to the spark plug. Also clean the spark plug wire end that goes on the plug. I use fine sand paper or emery cloth. Your choice.
Good luck and let me know if this works.
thanks
roundo4
Sep 02, 2009 | Garden
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
