Drive Belt for Sansui SC2002 Tape Deck
Hi, I am looking for a drive belt for a Sansui SC2002 tape deck. Any ideas where I might get one. Thanks, Kevin.
  • 4 Answers
SOURCE: equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Posted on Nov 03, 2007
  • 518 Answers
SOURCE: Tape deck not working
Sounds like a motor problem. Try turning the motor by hand to see if it's bound up.
Geno
Posted on Feb 27, 2008
  • 4234 Answers
SOURCE: missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Posted on Mar 25, 2008
  • 518 Answers
SOURCE: DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Posted on Apr 04, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
TAPE DECK
The number two deck either needs a new belt or there is something else wrong with the take-up drive to the reel table. This needs looking at and if you can not do it then a Tape deck Technician will be needed. They are around and that is what I do full time.
skywavebe@sbcglobal.net if you want it repaired
Oct 21, 2012 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
I have a sony TC-WR770 twin tape deck. The 1st deck is running with inconsistant speed causeing slurring of sound,also it will not fast forword.Can this be repaired and if so how? or is it now to old.
It could be either a worn roller, but more likely a belt problem. It's often a good idea to replace the belt(s) as the are rubber and wear out easily. They are not expensive either. Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Make a note of how it fits before replacing them, that's if you can do it yourself of course!
Feb 07, 2011 | Sony Dual-Deck Cassette Player/Recorder...
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
I need a drive belt for Sony tape-cd player #CFD-17
All you need to do is measure the diameter and thickness, then enter the details into google, just start with the diameter you can then elimanate the wrong size (thickness) later. IE enter: 60mm Drive Belt.
Jan 04, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Replacement drive belts for Sony HTC-H2900 tape deck
CPC, Chas Hyde, Willow Vale, Wizard.
Or you can measure the diameter of the belt and enter it into google. IE 60mm drive belt.
Dec 29, 2009 | Sony Audio Players & Recorders
Sony deck will not drive tape
The belt is worn out already, so it need to be change. you can dissemble the deck then bring the tape mechanism to a shop and replace the belts.This will solve the problem.
Aug 24, 2009 | Audio Players & Recorders
Sony Cassette TC-WR535 BELT REPLACEMENT
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
56 people viewed this question
 Grubhead
Grubhead
