Question about Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher I bought a 2006 Kenmore dishwasher model #66516032400 and the water does not totally drain out from the dishwasher. There is always a small amount of water left at the bottom. Has done this from day 1.
  • 641 Answers
Check whether the drain line was assembled exactly as per Kenmore's instructions. Good luck!
Posted on Sep 11, 2007
My Frigidare dishwasher is not draining so I cleaned the filter. Will there always be a little water left in the lowest part where it drains?
There will always be a small amount of water in the bottom because the pump is an impellor type, not syphon or peristaltic. The water will be whatever is in the drain pipework after the drain cycle has finished. If the machine is leaving a lot of water, the it would be worth checking the drain hose isnt blocked or kinked, and the drain pump impellor moves freely
Jan 11, 2018 | Dishwashers
Is there a drain or screen to remove and clean, have small amount of water in botton of dishwasher, always there
A small amount of water is normal and is needed to keep the rubber gaskets from drying and leaking. If it still cleans good don't worry about it.
Dec 28, 2010 | Kenmore 24 in. 16039 Built-in Dishwasher
I would like to know if you have water left behind in the area of the drain is that normal? Should this be completely drained away?
No, it's totally normal, The pump can't totally empty the washer and the hose because once it starts pumping air and water the air gives least resistance so the water remains in the hose. When the pump switches off gravity pulls a small amount of water back into the drain.
Your washer is 100% fine.
Oct 16, 2010 | Bosch Evolution 800 SHE58C02UC 24 in....
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 02, 2010 | Dishwashers
Small amount of water covering bottom dishwasher-won't drain
YES IT IS WATER FROM DRAIN HOSE LEFT AFTER PUMPING OUT THE MAJORITY OF WATER AND IS LEFT IN HOSE.
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
We have water in the bottom of the diswasher we havegfot down to a part that we cant get off, i think there is food trapped and that is what is stopping it from draining any suggestions
DWs always have a residual amount of wtare left in them after every wash cycle as a means to prevent the heater buring out when it is switched on. With the power and water supply turned off you can either ladle out the water with a small cup or siphon it out with a piece of hose or plastic tube.
Nov 08, 2009 | Kenmore Dishwashers
Our GE Dishwasher model GLD4500N00BB will only drain a small amount of water out of the dishwasher. there is water left standing after a wash. what is going on?
Look for restricted drain system. Screens and ports get plugged, also verify the drain hose is NOT kinked at all. Hot water draining relaxes hose and can cause restriction.
Oct 31, 2009 | Dishwashers
Standing water at drain in dishwasher after using.  Is this normal or should the water drain completely.
Most dishwashers leave a small amount of water in the bottom to keep the seals lubricated. If it is only a small amount of water it should be normal.
Jul 09, 2009 | Dishwashers
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
308 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
