Question about Boating
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
  • 52 Answers
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
    Novelist:
  • 184 Answers
Capt Jeff has the most common problem. I have also found the flexable wire coming from under the fly wheel has caused this same symptom. Hook up a timing light to the ignition wires at the spark plug and spin the motor while advancing the throttle. If the ig faulters during the spark advance- thats the problem.
Posted on Dec 13, 2011
I have a 50hp johnson outboard at full throttle it lags in power will not plan out but if I restrict or pinch fuel line between motor and the inline bulb it plans out nice runs perfect.
The fuel line from the tank to the engine may be collapsing as the pump demands more pressure! If you know someone with a fuel line with the same ends, ask to borrow it! If the problems goes away, invest in a new fuel line. When this engine was built ethanol was NOT being mixed into gasoline. Ethanol will melt some of the older fuel hoses (including those under the engine cover). Good luck!
Aug 20, 2017 | Johnson Boating
1973 Johnson 65 hp outboard. It runs smooth, but won't accelerate at full throttle.
have the carby professionally overhauled
replace all rubber hoses from the tank , including having the fuel pump overhauled
the rubber parts break down and deposit small bits rubber in all of the jets in the carby
Jul 20, 2017 | Johnson Boating
1993 Johnson outboard while running good will go from full throttle to barely running sometimes 5500 to 2500rpm. Carburetors rebuild gas lines good and good spark.
If your boat has a inboard tank check the Anti Siphon valve. Try to run the outboard on a separate fuel tank to isolate the fuel source to see if it is the boat or the engine. A clogged vent line will also do that.
Mar 30, 2016 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Evinrude motor problems
clean the carb jets etc and check fuel pump diaphrams not hard or perished ! balance the carbs also !
Aug 05, 2014 | Sierra Outboard Starters Johnson/evinrude,...
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
My 1988 johnson outboard 50 hp motor dies off when given full throttle
Any fuel filters? If the fuel line is old I would replace it due to the ethanol in gas. If not that then clean the carburater, high speed jet may be clogged.
Aug 23, 2010 | Raymarine Linear Feedback Unit For...
30HP JOHNSON OUTBOARD RUNS FAST ONLY WHEN IT WANTS TO!
is it one coil for each cyl or a double ht ? if single coils swop over and see if problem moves ! if double ht then swop leads over if you unbolt the coil and fit an earth wire to the coil body and try in a dustbin of water ! sometimes the ht are too short to swop ! check connections and earths !
Jun 11, 2010 | Light Outboard Motor Boat Bass Fishing...
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
Need to know how to set up carb on 1985 johnson outboard. front adj on the carb got moved looking for starting point to get me close to running.
try disconnecting the throttle cable, loosen carb linkages, assure that both carbs are FULL closed....tighten linkage - and cable ...check for FULL open and close with the throttle....this will be your starting point, advise to get a service manual for your outboard model to correctly adjust the carbs for max performance....GL hope this helps..
Jul 04, 2009 | Sport & Outdoor - Others
Boating Logo
1,187 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
