Question about Compaq iPAQ H3630 Pocket PC
Problem with 3630
Put a new batt in my 3630 now when you take power cord off it turns off batt appears to have charge tried a reset no difference thanks
    Scholar:
  • 57 Answers
Unfortunatly this isnt a new issue. http://computing.net/pda/wwwboard/forum/838.html It sounds as though your recharging system has went on the fritz. If this is the case then money signs are going to soon be appearing. replacing the charging system is impracticle and the system blocks startup so this would even cause a new battery to not function properly and also probably what ruined your previous one.
Posted on Sep 12, 2007
SOURCE:
My Kindle fire won't move past the start up "kindle fire" screen. what is wrong and how do I fix it?
Hello
Reset the Device:
If your Kindle Fire won't move, this doesn't necessarily mean that it's "broken" or has a major problem. The Kindle Fire has a tendency to become "stuck," meaning that it looks like it's "off" when it's actually "on" but it will not work properly because it's locked up. To unlock the Kindle Fire, do a reset by holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to get the Kindle Fire up and working again.
Charge It:
If resetting doesn't work, it's possible that your battery is dead. Try plugging the Kindle Fire into the charger and wait about 15 minutes before trying to turn it on again. If the device refuses to start up, try resetting it again.
If it still won't move, it's possible that you have a dead charging cable. Alas, the cables that come with the Kindle Fire are not known for their longevity. Try charging the tablet with another cord that has a Micro USB connection and see if the device responds. There's no guarantee that the charging cord from your smartphone will work with the Kindle Fire, but it's worth a try. If you get a bit of a charge, then you'll know that your Kindle Fire needs a new charging cable.
Try a Different Power Source:
if the charging cable appears to be working but the tablet still won't move, try plugging it into a different power outlet or the USB port on your computer.
If all of these troubleshooting tips fail, your Kindle Fire may have a hardware problem that requires professional help.
Visit here:
Kindle Fire Support
Apr 23, 2017 | Tablets & eReaders
About my emachine laptop model d725,cannot charge even my batt is new
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 24, 2011 | Computers & Internet
Why does laptop stop working through adaptor after battery flat
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Jul 10, 2010 | Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Battery wont charge and will not power without battery
It sounds like you have a bad power supply (power cord). If you already know someone that can charge your battery, check if their power supply will fit. It probably will. Make sure the plugs (into the laptop) are the same, and make sure the output voltage is the same on both power supplies.
Dec 17, 2009 | Dell Inspiron 1000 Notebook
Charging red light flashing on and off have a new charger and still rd light flashing
Try this i tired it and it worked... If not you may needa new batt. Just plug the power cord into the craddle, not the usb. Then put the camera on the craddle and let the red light come on, but not long engough to let it flash. Repeat this like 10 - 12 times jsut putting it on for a couple seconds. This will boast the batt engough to let the camera software know that once you put it on the dock that is is suppost to charge! Good luck any other questionos you can email me at [email protected]
Nov 07, 2009 | Casio Exilim EX-S880 Digital Camera
Is there a way i can restart my ex-s880 exilim camera so it will turn on?
Are you having problems getting it to charge if when you put it on the charger the red light blinks then try this : I tired it and it worked... If not you may needa new batt. Just plug the power cord into the craddle, not the usb. Then put the camera on the craddle and let the red light come on, but not long engough to let it flash. Repeat this like 10 - 12 times jsut putting it on for a couple seconds. This will boast the batt engough to let the camera software know that once you put it on the dock that is is suppost to charge
Nov 01, 2009 | Casio Exilim EX-S880 Digital Camera
I have an acer aspire one notebook. lost the cord. batt ran dead all the way. bought aa new charger & it won't turn on. what is wrong?
What you should do is charge the battery all the way up first WITHOUT turning on your notebook.
Usually when charging a light will appear - when that light has disappeared your notebook is fully charged and it should now turn on.
Good luck
Oct 27, 2009 | Acer Aspire One PC Notebook
Not turning on
take the batt out the sys. then put the charger. wait 3 min after that turn your sys on.
without the batt. if it turn on. your batt is damaged. if it dont turn on without the batt and
just the power cord is there. then your power suply node is broken or just no good.
if the sys goes on wait 11 min must 11 min exact. them put the batt on it and take the
power cord off. if sys stays on. your ok.
Dec 30, 2008 | HP Compaq NC6400 Business Notebook
When I turn the camera on the following message appears- high camera temperature, camera will shut off. The camera is a Kodak easyShare Z710
Have Kodak Easyshare V1253 with same, "high temp.," error then shutdown. Kodak batt. showed 25% charged. Charged batt 100% & temp. error went away. Batt. internal shows camera if batt. too hot. Try new batt.
Sep 12, 2008 | Cameras
Compaq iPAQ H3630 Pocket PC Logo
164 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
