The last time I moved my oven it took a few days before it started working again after being unplugged for a couple hours. power is fine, light, clock, etc, but none of the buttons respond when touched, and i can't cook with it. what causes this, and how do I get it to respond and work again?
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE
Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
SOURCE: suggestions
check the touch pad or control switches, and check the control panel circuit, check the thermal sensors. check the wiring.
SOURCE: Westinghouse WST3501 Microwave
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the
cooktop can damage the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
SOURCE: dead keypad
need to check keypad ribbon tail or connection. vibration from moving unit could have made it come loose. if connection are good then replace keypad.
