Drum does not turn
Indesit W63 - Drum does not turn after startup
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
GOOD MORNING I HAVE GOT A OLD INDESIT W63 ABD THE DOOR HANDLE BROKE -- WANT TO KNOW WHERE TO FIND A NEW ONE. REGARDS HENNIE DE WET SOUTH AFRICA
Hi from retired Englishman in SW France!
I'm sorry but I suggest you will have to use a lot of time and your web browser to see if there is a spares supplier that can supply you with one. The likely-hood of someone on the forum having one is.......................NOT ;-0)
Very difficult obtaining spares for older machines I fear.
Sorry again and good luck!
John C
Mar 01, 2011 | Washing Machines
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
When I turn the drum it sounds like it is rubbing on something between 11&1 oclock on turning cycle indesit w123s
have a tecnician take a look at cause it'' be hard to fix at home.
something between the motor and the drum has loosened which may also cause short-circuit in the future, so just watch out...
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Indesit W 123 Front Load Washer
What is the whole name of this motherboard W263661-w63-22-07-36
The Motherboard model is displayed on the screen for only a moment.
When you first turn on your computer while it's counting is memory, at the bottom left side of the screen you will see a date and a number, similar to the ones you have.
On my computer this is what I get:
My Motherboard is a CUV4X, Search that in Google and the rest of the information can be discyphered from that.
I recomend searching for only one of the portions of the display at a time, One will come up with Motherboard Results.
WIndows does have a way to block this screen from being visible when the computer first starts up, so you may not get the glimpse of this information, but if you do, it will be only for a second or two, so you will have to get a video, picture or pause the machine for a moment to be able to read what it says.
The Pause button is close to the Home key on the keyboard, hit it when the memory is counting, then press Enter to resume the boot sequence.
Good luck.
Richard.
Jun 23, 2009 | Computers & Internet
Indesit 1570c - it heats but the drum does not turn...
You probably have a broken belt. You have to remove the shell and reroute the belt. You can do it yourself for bout 20 bucks...Good luck. Look in your manual for proper routing of the belt. good luck.
Apr 17, 2009 | Dryers
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit WA105 - drum is loose and fails to spin
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Jul 23, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
