Question about Sony Dual Shock 3 Controller for PlayStation 3
Dual Shock 3 Doesn't seem to work at all
I just bought a Dual Shock 3 for my PS3 and it doesn't seem to work at all. I plug it in and the other controller won't work. I try to use it plugged in and not plugged in and it doesn't connect to the PS3. I downloaded the latest upgrade and it still doesn't work.
There's no instructions in the pack and I can't seem to find anyone on these forums with a similar problem, does anyone have any suggestions?
I have the perfect solution...
step 1- plug usb into controller, make sure the system is off
step 2- press thee reset button on the back of the controller then turn your system on with the systems on-button
step 3- once the system is on, press the ps button.
step 4- remove the usb and then pres ps again
step 5- it workz, gud lukk!
Posted on Oct 16, 2011
Brand new Sony dual shock 3 analogs not responding like my other ps3 controllers
Take it back to the shop if it is under warrantee. Don't mess with it and destroy your warrantee.
Mar 11, 2014 | Sony Dual Shock 3 Controller for...
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
I just bought a Tomee SX-3 PlayStation 3 controller and when i plug in the wireless USB part and turn on the power switch on the controller it doesn't seem to sync or find the controller? do you have...
According to a comment at Amazon "since firmware 3.5 Sony has blocked 3rd party USB accessories so this no longer works with a PS3. This isn't the companies fault, just be aware it no longer works on the PS3" http://www.amazon.com/PS3-SX-3-Wireless-Controller-Playstation-3/dp/B0031BWM6A
Jul 23, 2011 | Sony Playstation 3 (PS3) Console
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My dual shock 3 is not lighting at all. i tried connecting it on my ps3 and laptop using different usb cables but still when i press the ps button it didn't ligh
This usually happens when the controls have lost most of their power.
Try leaving your controller plugged in (charging)overnight or for like 2 hours. (Controls only charge with the PS3 ON).
Jan 18, 2011 | Sony Dual Shock 3 Controller for...
MY dual shock 3 sixasis don't work for some reason , when i press the ps3 butom the port indicator just flashes for 30 seconds
have you plugged the controller in with the usb cord to "reconnect" it ? if you haven't that should probably fix it
Mar 04, 2010 | Sony Dual Shock 3 Controller for...
Ps3 compatiblity with vibration and rumble feature
Greeting Vikas,
You do need a firmware update to enable the Dual Shock feature on your system. On the XMB (main menu), go to Settings and click on System Update. If you have internet connected you will be able to download the newest firmware there. Here is a link to a site with all of the Dual Shock compatible games For Japan, Europe, and USA.
http://www.videogamechat.net/tokyo-game-show/TGS-2007-PS3-Dual-Shock-3-Compatible-Games-List-316
I hope this helps! Good luck to you!
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Dual Shock 3 Controller for PlayStation 3 Logo
960 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
