Question about HP Office Equipment & Supplies
Hp 4200 printer wont print Itimes so probably have over loaded the memory in the printer
    President:
  • HP Master
  • 990 Answers
Hello sir; Remove the toner cartridge look inside bottom of the machine does discharge corona wire is broken? if not try to print out site map or configuration page. if do print something out then change a new cartridge.
Posted on Apr 12, 2009
Hp laserjet 4200 printer printing vertcal faint line
Check the cartridge and make sure that there is no scratch on any of the cylinder. If any cylinder is scratched you will need to replace it. Perform a cleaning with isopropylalcohol in these cylinders if they are not dirty and test the printer. If the problem persists, probably the fuser film is damaged and will need to replace it. If the line still continues to appear, the laser scanner may be dirty or damaged. Try to clean it or replace it.
Apr 11, 2012 | HP Office Equipment & Supplies
My Hp laserjet 4200 printer error is 53.10.03
Memory DIMM failed RAM test. Probably needs to be replaced.
Sep 22, 2011 | HP LaserJet 4200n Printer
New computer with windows 7. tried hookng up 2 hp printers, 952 and 4200. can not print from quicken on either printer. word prints on the 4200. i would prefer the 952 but the computer isn't full...
There is probably a qbprint.qbp file in your QB directory. You need to remove it from that directory (cut and paste it somewhere else), then open QB and go to Printer Setup. It will recreate that qbprint file for you. If that doesn't fix it I don't have any other suggestions.
Good luck
Sep 25, 2010 | Computers & Internet
Getting and err code 49.4c02 service error what does this mean?
4200 49 Error Troubleshooting
Power off the printer before removing the JetDirect, Hard Drive, formatter or memory modules.
Disconnect parallel and/or network cables. (power can be on)
Attempt to duplicate error using only built in test prints.
After determining if you can get errors with the built in tests continue troubleshooting.
Hopefully you will find the problem without having to go through all the steps.
If the printer has a network interface, then power off the printer, remove JetDirect, power on and test machine.
If the printer has a hard drive installed, then power off the printer, remove the hard drive, power on and test machine.
If the printer has more than one memory module installed, then power off the printer, remove the extra memory modules , power on and test machine.
If the printer had more than one memory module installed, then power off the printer, remove the memory module you left in it at the last step, install one or more of the modules you removed, power on and test machine. (if you don't have enough memory the results might be odd)
If the printer will go to a ready state, then attempt to load a firmware upgrade, do this even if the firmware version is current, you might have corrupted firmware.
If the printer will not go ready, and you have already done the steps before this, then perform a cold reset. (if a cold reset is done with a JetDirect installed it will reset all the TCP/IP settings, etc.)
1. Turn the printer power off.
2. For HP Laserjet 4200/4300 Series printers: Hold down SELECT, and then turn the printer power on.
3. Continue holding down until all 3 control-panel lights flash once and then stay on. This could take up to 10 seconds.
4. After the message SELECT LANGUAGE appears on the display, press UP ARROW or DOWN ARROW until COLD RESET is highlighted.
5. Press Checkmark, The printer then performs a cold reset and finishes its power-on sequence.
If there is another 4200 available power off swap memory modules with it, unless you've already proved the memory is working.
If there is another 4200 available power off the machine and swap the formatter cage with it, the formatter is the board that the EIO slots are on, also the parallel port is part of this board. (the formatter cage is held in by two screws, it slides straight back after the screws are removed.
If a cold reset does not help you can try an NVRAM initialization, it is not likely to help, but at this point you are getting desparate.
NVRAM init
1. Turn the printer off.
2. Remove all installed accessories (for example, a stapler/stacker).
3. For HP Laserjet 4200/4300 Series printers: Hold down SELECT, and then turn the printer power on.
4. Continue holding down SELECT until all 3 control panel lights flash once and then remain on. This could take up to 10 seconds.
5. Press UP ARROW.
6. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
7 Press until NVRAM INIT is highlighted.
8 Press Checkmark The printer initializes NVRAM and then continues its power-on sequence.
Jul 23, 2010 | HP LaserJet 4200dtn Printer
Hi I have problem with printing first page HP 4200
The toner has probably been affected by dampness or humidity while in storage. Cartridges will not last forever once they have been opened., try a new cartridge.
Feb 10, 2010 | HP LaserJet 4200 Printer
HP 4200 10.0000 supply memory error
It appears that the printer is having problems reading the e-label on the print cartridge. Remove and reinstall the print cartridge, then press the Select button. That should clear the problem.
Apr 07, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Install jet direct in hp 4200
Hi , I need to know why do you require Jet direct . if its for admin then you can use jetadmin.
Apr 02, 2009 | HP JetDirect 4200 (j4117aaba) Print Server
HP 4200 printing very light, smudgy and blurry
Remove the rear door by pulling it down and squeezing the left tab to remove it.
Press the blue hooks and remove the fuser. Look for a worn coating on the gray roller.
Feb 19, 2009 | HP LaserJet 4200 Printer
HP OFFICEJET ALL IN ONE 4200
maybe..go here to check
www.hp.com
and go through the model number selection process.if it's listed, you're in.
http://tinyurl.com/6qcpgy
Aug 17, 2008 | Brother HL-2040 Laser Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
