Question about Metra Ford F 150 Truck 1999
I need wiring diagram for trailer lighting - Metra Ford F 150 Truck 1999
  • taylorverne May 05, 2009
    My left brake light doesn"t work but everything else does. Can anyone help me withthis problem.
  • 32 Answers
Check your bulb first. check if voltage is getting to the bulb 2nd. check the ground connection 3rd (the ball hitch is the ground connection). If none of those things--you need to do some wire checks.
Posted on Jun 14, 2009
TAIL LIGHT WIRING DIAGRAM 2014 KIA SORENTO
Hi. Thanks for your question. For the diagram of Tail Light you can visit https://www.reliable-store.com and download the entire workshop manual. It has all the information along with the diagrams for better understanding. Good day!
Feb 18, 2018 | Kia Cars & Trucks
I need a trailer wiring diagram for a 2000 dodge dakota sport
Dark green with red wires the left stop turn signal Dark green with brown is the right stop turn signal Black with yellow is the tail lights.
Sep 08, 2012 | Dodge Dakota Cars & Trucks
Need wiring diagram for toyota matrix to a trailer
I am sorry but fixya has no wiring diagrams to download due to copyright laws.
Jul 23, 2012 | Cars & Trucks
Factory 99 dodge trailer plug wiring
You'll need to disconnect the wires from either the truck connector or the trailer connector...
I highly suggest purchasing a voltage checker- it looks like a screwdriver with a pigtail of wire with an alligator clip on the end. The tip of the 'screwdriver' has a point for probing. The light in the probe will light up...makes it easy to trouble shoot without a helper behind the trailer.
Hook the aligator clip to a good positive grounding point on the bumper or frame(not painted).
then pin by pin on the truck connection, stick the probe on each terminal tab.. and write a simple diagram where you find brake, tail, backup, etc...
Then i'd suggest, taking the connector off of your trailer, exposing the wire ends.
Run again thru your diagram and turn on each light of the truck. As you do, touch the wires from the trailer to that specific terminal. (make sure your ground wire is attached on the trailer) you can mark each wire with a piece of tape and label it which is which.
then simply attach your trailer wires according to your diagram to the terminals in the connector... that should get you in business..
hope that makes sense...
That way if the factory wiring harness remains the same, you'll be able to use it with other trailers if the need arises..
May 28, 2009 | 1999 Dodge Ram
Wiring diagram from truck to trailer
Get a tester light the type with an alligator clip and a sharp point.
Check each wire for your brake lights,blinkers etc.
i.e. With the blinker light on find the correct wire and splice into it with the corresponding light on the trailer. ( DO NOT CUT THE TRUCKS WIRE)
Remove the covering and twist the plug wires around it and tape or shrink wrap if you can.
Hope this helps
Apr 19, 2009 | 1999 Dodge Dakota
Wiring diagram or fuse box diagram-2007 GMC Envoy Denali
Hi there;
Here is the wiring diagram for the trailer wiring for your truck.
Hope this helps
Farrout!
Mar 07, 2009 | 2007 GMC Envoy Denali
I need to add a trailer light plug to my truck. i need the tail light wiring diagram for a 2005 toyota tacoma pickup.
The diagram will do you no good it you do not have amber turn signals on your trailer. What you need is a "black box" that, when wired correctly, interprets the amber turn signal on the truck into a pulsed flash to the red brake lamp on the trailer. If the trailer does not have amber turn signals, it is impossible to wire a harness with a diagram. Sorry.
Aug 08, 2008 | 1995 Toyota Tacoma
Metra Ford F 150 Truck 1999 Logo
738 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
