Evesham V30DMCX TV working OK up to the time it was switched-off. When it was switched-on the next morning no results, no red indicator light. Assuming no power, mains-lead checked and another lead tried.Power socket checked and another tried. I was a TV service engineer a few years ago but before I delve into the interior, I would like to have a circuit diagram and some info on the possible causes.
  • 19,396 Answers
If there is no led on and no power at all , then the problem can be isolated to the power supply board and power cable.
Testing power cable is easy, you can read voltages, or continuity between plug and solder joints on power board.
The power board is not much different from what you had on old TVs, only on many LCDs there is no built in High voltage circuit, and the high voltage board is an inverter located underneath the display.
Only on few models the inverter is located on the same board as power supply, in that case you should recognise an high voltage circuit aside the low voltage power circuit on same board.
Usually LCD TV have separate inverter board , this makes testing much easier.
The fact that you are a TV repairer is really useful, as Evesham Technologies closed down, and now it is very difficult to find a service manual with part list or an original replacement power board. I am having troubles myself in finding Evesham parts. See : Evesham Technology goes into liquidation or Evesham 37" lcd faulty power supply board - help repair .
Also not having any power at all is a good sign, If you had a fault somewhere else than power board, then the TV would have stayed on protection mode, with the led blinking.
to fix the power board do the usual, check capacitors after allowing discharge, when they blow you can usually see they are bulged or leaking. Then have a general look to the board to spot cold solder joints, and then proceed on testing components, this is not a complex board, and if you know how to solder and use multimeter this should be an easy task.
Posted on Apr 12, 2009
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
What was the code did all work cause i can not get it to work at all
Hello
Just try one amoung the following codes. I've only these three codes are available with me for Jensen Tv.
{ 0004 _0009 _0133 }
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note:- If one amoung the above four codes did't work, try the other after the TV is switched off and switch in again after some time, say at about 10 seconds, and try the other. Not enter the code continously without turning it off, after one code won't work. Ok.
__________________________________________________________________________________
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Oct 25, 2010 | Jensen TS2050J 20" TV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
Panasonic CT36SC13G Wont turn on.
The power supply may have failed
Jun 30, 2017 | Panasonic Televison & Video
I have A Pioneer SDT50W1 rear projection TV which is about 11 years old. It is in A1 condition but recently I have had a problem when turning on the set. When I press the on off switch on the front of the...
The most likey cause of this is poor solder connections either in the power suply area or the convergence circuit area. If you can solder and are comfortable working inside the set where there are potetially dangerous high voltages (even when unplugged), you maight be able to resolve this yourself. Try resoldering any connections on the boards that appear grainy or have rings. Update this with your results.
Thanks,
Dan
Feb 18, 2009 | Pioneer Televison & Video
Unable to boot at all
Overheating problem. Pls get a technician to clean the processor and apply a fresh layer of processor sealant and also clean all the fans.
Jun 08, 2008 | Evesham Voyager 6400 PC Notebook
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
