I have a TruTech T600-D DVD/CD Player. I am trying to connect it to my Emerson tv. I had it hooked up and working fine, then I moved to another state. I tried to hook it up again exactly how I had it before and now it won't work. I hooked it up using the Composite connection but got nothing. I also tried calling the technical support number for the company, but could not actually talk to anyone.
-   My Trutech DVD/CD Player is stuck in the Standby Mode and I cannot get it out of that mode. I believe the cables are hooked up correctly. Any suggestions?-   kkkaren
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable.
Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow)
Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red.
At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks.
I hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Jul 19, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
**** ALL YOU EINSTEINS THIS IS TO IFFICULT!!!!!!11
We are looking for a new DVD recorder that will last longer than our last one a RCA. we just want...
(More)
We are looking for a new DVD recorder that will last longer than our last one a RCA. we just want simple recording from our TV or computer.
DVDR520H purchased in Saudi and worked well, but cannot re-tune to UK channels? It works when I play...
(More)
DVDR520H purchased in Saudi and worked well, but cannot re-tune to UK channels? It works when I play discs or from the hard drive.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
