Question about Makita Rotary Hammer 1100 Rpm, 4500 Bpm, 7 Amp, ModelNo. HR2445X
Makita HR2455X rotary hammer leaking "oil"?
Where bit mounts, oil flies out while drinning, more while under pressure.
Apply less pressure and ignore oil.
Posted on Apr 14, 2009
My makita hr3000c won't hammer what is the most likely reason
Beware that its an old type Makita where several parts are not are deliverable any more lubrication is the first reason leaking 2 seconds and if its leaking it becomes hot inside has lost its pneumatic working so the parts are become hot and will be worn soon and the person who works with leaking tools overload themselves rather than the work object.
Makita has sometimes problems in front of the impact bolts by its rotary hammers. to observate the part cilinder 331559-9 very carefull if its not torn nowhere and this applies also to part tool holder 323912-3 it must be smooth inside in front where the impact bolt is sealed
Makita HR3000C Parts Breakdown
Oct 28, 2015 | Makita Drills
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
Makita sds max avt --when it is on the chisel only mode it still revolves like in drill mode . What has caused this ?
If the bit turns freely it's possible you have the change ring in the forward position. The HM0860C is a demolition hammer, not a rotary hammer so the bit should not be rotating under power for any reason. On the HM0860C the changing ring on the nose does slide forward to let you choose and lock the chisel bits in 12 different angles. Check to make sure the change ring is in the locked position.
Jun 30, 2012 | Makita HM0860C 11lb Demolition Hammer SDS...
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
What kind oil use for makita hm 1304bx1
What kind of oil is used in a Makita Demolition Hammer?
Oct 01, 2009 | Makita Hm1304bx1 Demolition Hammer +...
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Bits will not lock into chuck
First I would go to Makitatools.com and download a schematic for this tool. But it is pretty simple to remove the rubber dust shield and plastic collar to look for debris and proper movement in the chuck assembly. Make sure also that you are using the right SDS bits in tool. You should be able to push the bit into the collar and twist until it goes into and locks. Let me know and I will help further
Jan 10, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Usage Problem
Yes, but you have to use an auxiliary 3 jaw chuck adapter and you do it.
Aug 27, 2008 | Makita Rotary Hammer 260 Rpm, 2100 Bpm, 11...
Makita Rotary Hammer 1100 Rpm, 4500 Bpm, 7 Amp, ModelNo. HR2445X Logo
291 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
