Question about JVC TH-C4 System
Surround system how do i connect my system to have surround when using just tv is there a way to connect it that way to my tv
  • 752 Answers
You would have to have a tv with RCA audio outputs and hook those to an input on the reciever.
Posted on Sep 13, 2007
SOURCE:
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
How do i connect my hitachi tv to my surround sound system i tried red and whit cables as thats all i can connect to my surround sound system bit it does not work
The red and white RCA cords from the TV 's AUDIO OUTPUT must be connected to the INPUT of the surround system. You can counter check the input of the surround with another input like a DVD/VCR and if this works the TV output must be absent. Check if the connection was given to the OUTPUT and not to the input.
If not there is fault in the preamp output of the TV sound amplifer. You need to use a signal source to confirm. If not the earphone output can be used with a resisitor network for impedance compensation.
Sep 20, 2011 | Hitachi Televison & Video
Hi there I'm trying to connect my technics
are you trying to use the speaker system on your tv? or are you trying to get sound from your tv to your surround system?
you will need audio patch cables!
sound from your tv to surround:
line out on tv to line in on surround
sound from your surround to your tv:
line out on your surround to line in on your tv
Aug 22, 2011 | Sony Televison & Video
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How can i get sound from my Tv to go through my surround sound.
If you are using a "cable box" or "sat receiver" the audio will go from the cable/sat to the surround system with either optical, digital coaxial or analog RCA to the TV input on your surround system. If it does not have an input specifically labeled "TV" you can use vid 1 vid 2 etc. just make sure that when you wish to listen to the tv on surround that the surround system is on the correct input.
If you are using just an "off-air" antenna, your cables would go from the TV "monitor out" which will be either optical or analog RCA to the surround system and the appropriate input. Hope this isn't too confusing, if you need more help, post a comment and I will help some more. Hope this does the trick
Jun 15, 2009 | Insignia NS-H2002 Theater System
Not sure how to connect surround system to tv
Hi
Look on the rear of the tv and there should be an audio out connection coloured red and white and this will be a phono connection ( 2 small holes one red and one white) using a phono lead connect this to the same connections on the surround system only this time this will be an audio in connection select the tv channel on the surround system and ensure the tv is on and off you go. Try this and see how you go.
Dec 28, 2008 | Panasonic Televison & Video
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
JVC TH-C4 System Logo
50 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
