Question about Ovens
I have a whirlpool self cleaning oven. Model #RBD305PDB10 Ser#XK5101138 I was cleaning my oven and had about 20 minutes left on the cleaning but had to leave so I hit the off button and left. Now my screen says the correct time and under it says locked. However, my oven door will open. None of the buttons work other than the hour and minute
    Brigadier General:
  • 8,619 Answers
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
As you've interrupted the clean cycle,the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 12, 2009
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
How to clear F2 E1 error on a whirlpool double oven
E1 F2 is most often due to a failed keypad. Depending on your exact model the original part may be no-longer-available. However, there are replacement membrane switches available here:
Introducing the Ledgestone Technologies Touchpad
Models: RBD305PDB10 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDB14 RBD305PDB15 RBD305PDB7 RBD305PDB8 RBD305PDB9 RBD305PDQ10 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDQ14 RBD305PDQ15 RBD305PDQ7 RBD305PDQ8 RBD305PDQ9 RBD305PDS12 RBD305PDS14 RBD305PDS15 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD305PDT14 RBD305PDT15 RBD305PDB1 RBD305PDB2 RBD305PDB3 RBD305PDB4 RBD305PDB6 RBD305PDQ1 RBD305PDQ2 RBD305PDQ3 RBD305PDQ4
Jan 08, 2014 | Whirlpool RBD305PD Electric Double Oven
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 19, 2011 | Whirlpool Ovens
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
Nov 15, 2010 | Whirlpool Ovens
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven won't restart after self cleaning. What to
Try resetting by turning off breaker for a couple minutes then turn back on. If this does not do it you will need to acess you door latch switch. This is acess by removing the top panel. Check for continuity with latch open you should have none and you should have continuity with latch closed. You can enter your model # at www.appliancehelponline.com to bring up illustrations and parts.
Mar 28, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
